67 Cutlass front turn signals
I have a 67 Cutlass Supreme that has the split headlights (with turn signal in between). I have the headlight buckets and I am having troubles/ questions on the light bulb socket. Has any one replaced this ? It seems to be pressed in, in some fashion and am looking for ideas on replacing it and who should I buy them from
You might also be able to use one like this, bending the tabs over to secure it and using silicone to seal it.
And finally, you might be able to simply replace the contacts with one of these:
oldspackrat
Jan 20, 2015 09:16 AM
