67 Cutlass front turn signals
Old May 19, 2017 | 09:21 PM
brianbeez67's Avatar
I have a 67 Cutlass Supreme that has the split headlights (with turn signal in between). I have the headlight buckets and I am having troubles/ questions on the light bulb socket. Has any one replaced this ? It seems to be pressed in, in some fashion and am looking for ideas on replacing it and who should I buy them from
Old May 20, 2017 | 09:27 AM
The sockets are swaged into the turn signal housings and are not designed to be replaced by themselves. You would need to cut or machine the old sockets without damaging the housing and then find replacements that could be installed. Some vendors sell generic sockets that attach to a housing with two screws an a gasket.
You might also be able to use one like this, bending the tabs over to secure it and using silicone to seal it.
And finally, you might be able to simply replace the contacts with one of these:
Mak
Jul 27, 2011 08:39 AM
crazy'boutOlds
Jan 28, 2011 10:05 AM
jpaulwhite
Mar 27, 2010 08:38 PM
palmers65
May 30, 2008 11:12 AM
