'67 Cutlass Front Turn signal screws
Old May 3, 2022 | 11:06 PM
outrightolds's Avatar
Outrightolds Creator
So I bought a specific for my year screw kit- and I am replacing the original screws for the front turn signal lenses.
The screws in the kit are too long, and attempting to use them does not work. I tried to dremel one screw to shorten it, but it just messed up the thread.
Are the turn signal lenses held in with a plastic nut similar to what the headlights have? That is the only way I can see a longer screw working, the original screws that were there are half the length.
Old May 4, 2022 | 07:06 AM
nicks1966's Avatar
The lenses are held in by machine screws, they thread directly into the headlight housing. I have a headlight housing off the car if you want pictures of the housing and screws.
Old May 4, 2022 | 10:32 PM
The rusty screw is the original, the long one is what came with the kit, and the other was my cut up one--- but when you mentioned its just a machine screw, I went out to the hardware store and found a #8-32 x 3/4 in. pack of screws that worked just fine! Thanks!
Old May 4, 2022 | 11:09 PM
Glad you got it figured out.
Here's a tip:
I always put a nut on the screw so that after cutting it to length, backing the nut off cleans up the cut edge of the thread.
Old May 5, 2022 | 09:10 PM
Here's a tip:
Great tip, thank you for that!
loserelli
Oct 8, 2021 04:35 PM
deadeyejedi
Apr 12, 2018 06:20 PM
Flye
Aug 10, 2011 05:18 AM
KZ442
Dec 7, 2009 06:11 PM
Flye
Apr 7, 2009 02:34 AM
