Look at these welds
Old Oct 11, 2016 | 06:14 PM
DewChugr's Avatar
Photoshop God
Look at these welds
I just got my rear end blasted and ready to paint. Do these welds look ok or should I take a few minutes to make these a little better?
Old Oct 11, 2016 | 06:26 PM
76olds's Avatar
Hookers under Hood
They certainly won't break, Good penetration where it is welded IMO.
Eric
Old Oct 11, 2016 | 06:52 PM
DewChugr's Avatar
Photoshop God
Eric
Thank you Eric. Just what I needed to know. On to paint.
Old Oct 12, 2016 | 04:55 AM
Professur's Avatar
I wouldn't want to put my name on them, but they haven't failed since they passed factory inspection.
Old Oct 12, 2016 | 01:51 PM
bassinguy's Avatar
In my opinion as a retired certified welder, I would had ground out the weld and re welded the brackets. In the first pic you can see a crack and second pic ,you have a weld that is not fully welded. Weld do fail after years of use. You had the housing out,cleaned and ready to fix. As you said it would only take a few minutes. Just my 2 cents worth.
Old Oct 12, 2016 | 02:00 PM
DewChugr's Avatar
Photoshop God
OK, thanks. I might go ahead and do that. Do you know if you can weld through the zinc phosphate coating? I've heard that you can, but don't know.
Old Oct 12, 2016 | 02:05 PM
bassinguy's Avatar
That I don't know. I always had clean metal.
Old Oct 12, 2016 | 09:26 PM
Oldsr4me's Avatar
Having done quite a bit of soldering in my younger days, a couple of them look like what we called "cold" joints. Very poor adhesion where the weld doesn't melt into the metal. We wanted to see a smooth flow onto the metal.
This fault would happen when one metal wasn't brought up to the proper temp as the other. Thus, a cold solder (weld) joint.
Check these out
ATTACH]141990[/ATTACH]
smash72
Sep 11, 2016 02:12 PM
Rocket Richard
Body work
Jan 23, 2015 05:30 AM
smash72
Jun 26, 2014 04:41 PM
sammieolds
Drivetrain/Differentials
Jul 30, 2010 12:15 PM
Thuffner3
Dec 11, 2007 07:38 PM
