Should these welds make me nervous ?
Old September 7th, 2016, 09:55 PM
Smash
smash72's Avatar
In the process of aupgrade front disc brakes, thought I'd do a bushing or two while all undressed. Then I notice these two welds. I have the same 72 Cutlass s sitting right next to this one for comparison. My other cars weld although not quality craftsmanship definitely a neater weld. Pics to follow. Question is was the guy hungover in 1972 or was this done by the PO and I have a serious problem. Or possibly just needs to be touched up. Thx
File Type: jpeg
smash72 is offline
Old September 7th, 2016, 10:03 PM
Smash
smash72's Avatar
Closer look
File Type: jpeg
smash72 is offline
Old September 8th, 2016, 07:29 AM
TripDeuces's Avatar
Unfortunately that weld only penetrated the bracket and not the frame. It's looks good on the side but that front edge is bad. Just a bad stick job. Have someone run a bead over that and you'll be fine.
I think that was from the factory. I think we've all seen welds like that on our cars some place. Just a bad day I guess.
TripDeuces is offline
Old September 8th, 2016, 07:34 AM
Smash
smash72's Avatar
I feel a little better so my frame doesn't appear to be cracked with this horrible tack job hiding a world of sins ? How dangerous if it's not addressed right away. I'm not driving the car more than text hits here and there. Thx
smash72 is offline
Old September 8th, 2016, 08:53 AM
TripDeuces's Avatar
How dangerous if it's not addressed right away?
It survived 40+ years like that. Just re-weld it for peace of mind.
Old September 8th, 2016, 09:48 AM
I agree with George, that weld looks original (though I can't say for sure), and seems to have remained intact for for 44 years, so there is nothing inherently dangerous about it.
I ASSume that what I am looking at is a hairline crack or space between the bead of the weld and the frame, running horizontally. You can check its behavior by jacking up the car on either side of the parts in question and seeing whether there is any change in that gap, and if so, how much. My guess would be essentially none.
You could get a better look at its condition by grinding it all smooth and looking at the crack pattern.
At that point you'd be in a good position to run a new bead and be done with it.
Remember, "back in the day," Monday-quality work and Friday-quality work were a real thing.
MDchanic is offline
Old September 11th, 2016, 02:12 PM
Smash
smash72's Avatar
Did the jack pressure on both sides no expansion on the weld. I will grind and clean it up and tack a nice bead on top frame looks good. Good looking out thx
smash72 is offline
Rocket Richard
Body work
January 23rd, 2015 05:30 AM
smash72
June 26th, 2014 04:41 PM
yeahbuddy
Suspension & Handling
23
January 15th, 2013 05:48 AM
sammieolds
Drivetrain/Differentials
July 30th, 2010 12:15 PM
Thuffner3
December 11th, 2007 07:38 PM
Quick Reply: Should these welds make me nervous ?
