How does one move a roller without coil springs
Old Sep 19, 2016 | 02:01 PM
Bitburger's Avatar
Anyone had experience with moving and trailer loading a roller ( 72 Cutlass )
that has no coil springs or shocks front or rear. There is no motor or trans in the car.
Will the body drop onto the tires without the springs ?
The car is 2 hours away and I wanted to go prepared.
Old Sep 19, 2016 | 02:39 PM
cdrod's Avatar
Rodney
My frame/chassis doesn't have the front springs installed yet, so I cut 2 short sections of 2x4 and slipped them into the spring pockets to hold up the front suspension, I don't see why you couldn't do the same in the rear, notch the ends of the 2x4s to sit down into the spring perches so they stay put. Should work well enough to move the car.
Rodney
Old Sep 19, 2016 | 02:41 PM
Yes.
Old Sep 20, 2016 | 05:08 AM
Professur's Avatar
Rodney
I'd use 4x4, but this is the standard method.
Old Sep 20, 2016 | 07:07 AM
I had to do this with an El Camino and used 6x6 chunks I had laying around (from building my pole barns).
Old Sep 21, 2016 | 09:28 AM
Bitburger's Avatar
Thanks for all the responses. Sounds like wood "struts" are the solution.
Brad
costpenn
Aug 29, 2018 11:42 AM
White Spyder
May 27, 2012 10:38 AM
Maverick
Mar 19, 2009 07:35 PM
ztim
Oct 24, 2008 12:06 PM
Redog
Aug 14, 2008 06:56 PM
