How does one move a roller without coil springs
Old September 19th, 2016, 02:01 PM
Bitburger's Avatar
Anyone had experience with moving and trailer loading a roller ( 72 Cutlass )
that has no coil springs or shocks front or rear. There is no motor or trans in the car.
Will the body drop onto the tires without the springs ?
The car is 2 hours away and I wanted to go prepared.
Bitburger is offline
Old September 19th, 2016, 02:39 PM
Rodney
cdrod's Avatar
My frame/chassis doesn't have the front springs installed yet, so I cut 2 short sections of 2x4 and slipped them into the spring pockets to hold up the front suspension, I don't see why you couldn't do the same in the rear, notch the ends of the 2x4s to sit down into the spring perches so they stay put. Should work well enough to move the car.
Rodney
cdrod is offline
Old September 19th, 2016, 02:41 PM
Yes.
Fun71 is offline
Old September 20th, 2016, 05:08 AM
Professur's Avatar
Rodney
I'd use 4x4, but this is the standard method.
Professur is offline
Old September 20th, 2016, 07:07 AM
I had to do this with an El Camino and used 6x6 chunks I had laying around (from building my pole barns).
joe_padavano is offline
Old September 21st, 2016, 09:28 AM
Bitburger's Avatar
Thanks for all the responses. Sounds like wood "struts" are the solution.
Brad
costpenn
August 29th, 2018 11:42 AM
White Spyder
May 27th, 2012 10:38 AM
Maverick
March 19th, 2009 07:35 PM
ztim
October 24th, 2008 12:06 PM
Redog
August 14th, 2008 06:56 PM
Quick Reply: How does one move a roller without coil springs
