Front coil spring clocking?
Old May 31, 2019 | 06:28 AM
71OldscutlassS's Avatar
Hello everyone,
I just finished my Winter - full frame off restoration of my 71 Olds Cutlass S post coupe. I replaced everything, body mounts, new control arm bushings (poly), Ball joints, added bigger swaybar, added 1" stock style rear sway bar ( + boxed rear LCA's and added frame triangular braces).
I always hat that issue, that my car is sagging about 1 inch on the left front corner. It did before the restauration and now after it, its the same. I tried everything and im so sick of this issue.
I always thought that the front coil springs are clocked correctly if the end of the spring is sitting in the deepest position of the front LCA. Today, i red in my 71 Chassis service manual, that the end of the coil springs should be BETWEEN the 2 small holes in the LCA's spring pocket. BUT - my LCA's just have one small slot hole in the spring pocket? So where should i place the end of the coil on these LCA's?
I hope someone reds my novel 😁
Thank you for your help, greetings from Austria!
Old May 31, 2019 | 06:35 AM
BTW, here are 2 pictures of the Chassis before i dropped drivetrain back in and the body back on.
IMO, the frame doesnt look bent or something. It also had no cracks or other issues.
Old May 31, 2019 | 11:46 AM
TripDeuces's Avatar
Place the spring so it covers the hole by about an inch
Old May 31, 2019 | 01:00 PM
Ok, i'll check that!. So my LCA's with one hole arent the right ones for 71?
Greetings
Old May 31, 2019 | 02:17 PM
Greetings
Yes, the ones on my car are the same with one hole.
Old May 31, 2019 | 05:36 PM
Macadoo's Avatar
Same here, my '71 has one hole. The CSM says to cover about half of the hole. FWIW.
Old May 31, 2019 | 07:14 PM
Yellowstatue's Avatar
The end of the spring should be visible in the slot.
Old May 31, 2019 | 10:39 PM
I saw this figure too, but i think the CSM says that thisbis not for A Body?
To place the springs that the end is visible in the slot makes sense to me.
costpenn
Feb 18, 2021 07:10 AM
Bitburger
May 10, 2019 05:19 PM
Inline
Feb 16, 2017 08:56 AM
sortasane
May 15, 2016 05:35 PM
wisniows
Nov 25, 2014 05:53 AM
