Intermediate Steering Shaft Spring Clip
Old Jun 1, 2019 | 02:49 PM
teamwieland's Avatar
This clip was holding the pot joint seal on the ISS. I pounded it down the end of the shaft with a screwdriver. No idea how this is getting back on over shaft and rubber seal. Is there a special tool like a type of pliers I need?
Old Jun 8, 2019 | 03:04 PM
bry593's Avatar
1968 442 Convertible
I sort of spread it out a little to relax tension. I greased the boot to make it slide easier, then was able to use needle nose vice grips to spread the tangs just enough to work it into place. It took a bit of fiddling, but it's possible. I assume the factory had some special tool.
Old Jun 8, 2019 | 09:02 PM
Thanks bry593. I followed your advice and made it work. One of the tabs broke off in the process but it doesn’t affect the clip. I bet you are right about the factory having a special tool.
501Paratrooper
Suspension & Handling
31
Feb 7, 2019 11:30 AM
yorkman
Jan 11, 2019 08:19 PM
BackInTheGame
Oct 18, 2015 02:03 PM
dc2x4drvr
May 2, 2011 11:10 AM
lll442
Nov 24, 2010 09:22 AM
