Intermediate Steering Shaft
Old Mar 23, 2013 | 10:11 AM
501Paratrooper's Avatar
Any tips on replacing the intermediate steering shaft rubber seal (pot joint seal)?
Thanks!
Old Mar 24, 2013 | 03:53 PM
Ok I dove in and it's not all that hard. I used this diagram and now I'm waiting on the seal and new steering coupler (rag joint).
Old Mar 24, 2013 | 04:17 PM
Have to agree with you - just sounds intimidating at the start. Did that 2 years ago, but my shaft rubber and coupler were in really good shape so I didn't have to replace them. When you put it back together use grease liberally in the rubber seal to hold those anti rattle clips. Excess will glootch out the end for easy cleanup. I see you found the pic in the CSM. The write up is quite good and easy to follow. Here's how mine turned out after cleanup and dry fitted together
Really nice how clean your washer got those parts!!!
Old Mar 24, 2013 | 04:27 PM
Lady72nRob71's Avatar
Great! And while it is apart you can paint it if desired. Reassembly tips can be found here:
https://classicoldsmobile.com/forums...tml#post301437
Old Mar 24, 2013 | 05:07 PM
Thanks fellas!
Old Mar 24, 2013 | 05:21 PM
starfire's Avatar
How did you get the cross shaft out? Mine won't budge.
Old Mar 24, 2013 | 05:28 PM
Did you remove the upper nut AND cross bolt at the top and the cross bolt from the rag joint?
The bolts have to come out as they fit captive in grooves.
Mine just pulled down and popped out after pulling all the bolts.
Old Mar 24, 2013 | 05:31 PM
If you mean the "T" you have to use a punch if you just hit it with a bfh it will mushroom.
Old Mar 24, 2013 | 05:38 PM
Good to know. A series of smaller taps or just whale on it with a drift? When I looked at the cross shaft (we're talking about the one on the end with the rubber seal) it looked like it was the same diameter all the way through, so it has to be pressure fitted.
Sounds like Rob is describing getting the shaft off the steering column splines.
Old Mar 24, 2013 | 07:16 PM
starfire's Avatar
I tried that (the punch that is), it won't budge at all. Tried it from both sides too. Not even a millimeter of movement either way.
Rob, I'm not talking about the rag joint at all. Look at Allan's top picture, way to the left, just left of the rubber boot, that cross shaft.
Old Mar 24, 2013 | 07:25 PM
Right. Okay, you mean the pressed in little stud. I would not know cause I left that part in mine. Looks to be pressed. Measure each side with a caliper. If both are the same diameter, use an arbor press and push it out from either side. If there is a smaller side, press on it. Reinstall the same way. Might have to find someone with a press though, or use a stout C-clamp and a socket over the pin's exit...
Old Mar 24, 2013 | 08:35 PM
+1. I really whacked it a few times, too. No dice.
I assumed it was unremovable after that.
Old Mar 25, 2013 | 03:54 AM
starfire's Avatar
So how'd you get the rubber boot back on? My new one won't stretch far enough to go over it.
Old Mar 25, 2013 | 05:11 PM
Never took it off - it was in surprisingly perfect shape.
Some soapy water will help lube it so it will slide on.
Old Mar 25, 2013 | 05:54 PM
starfire's Avatar
Oh. Mine had a slice in it so I got a new one. There's not enough soap in the world to get the new one past that shaft. I ended up buying an intermediate shaft that had a good boot on it, but I would still like to fix this one so I could sell it. I just can't get that damned cross shaft out. I tried heat, lube, cold, bigger hammer. I don't have access to an arbor press. I will try the socket and c-clamp and see if that will work.
Old Mar 25, 2013 | 05:58 PM
I was confused - I though you got the cross bar out and was trying to get the new boot on over the steery shaft.
Old Mar 26, 2013 | 09:43 AM
Guys, here is a write up on how to remove the cross pin on a Buick intermediate shaft. Same principle with pics.
Intermediate grease seal replacement
Mine came right out no problem? I wonder if yours got too hot at one time and expanded or something?
POWERSTEERING.COM fixes these as well and replaces all the little parts including the "T".
If no one cares about originality, here are some of the same parts as our cars except for the boot.
http://products.4wd.com/lower_manual..._110642416.php
Old Mar 26, 2013 | 09:45 AM
I broke the C clip on mine and cant find one like it anywhere. Anyone have any ideas before I resort to a flat cable tie.
Old Mar 26, 2013 | 09:54 AM
Sorry, Allen, but that did NOT work on mine, and I put some pretty serious hurt on it before I gave up.
It's nice to imagine it would work, though .
Old Mar 26, 2013 | 11:13 AM
Well it has to come out somehow. It was likely pressed in there, so it should press out. I never verniered mine. Anyone try to see if one side is slightly smaller?
Old Mar 26, 2013 | 11:40 AM
pcard's Avatar
70 Cutlass SX
Try your local GM/Buik dealer for the clip. They have alot of old stuff surprisingly and they can search nationally. I had luck finding a steering locking plate retaining ring through their system - cost was 0.25ea (I got two) with 5.00 postage.
Maybe 4wd.com will sell just the clip.
Cheers, Peter
Old Mar 26, 2013 | 05:34 PM
Thanks Peter
Old Mar 26, 2013 | 06:25 PM
I am sure some members here have some of these in their parts boxes or parts cars!
Old Mar 26, 2013 | 07:07 PM
Or the old junk yard.
These clips were used on essentially every GM car made for several decades, and the part can be popped out in seconds, just by leaning over the fender.
If you're buying several items at once, this one will likely be a freebie.
Old Apr 10, 2013 | 05:55 AM
All complete.
Old Apr 10, 2013 | 01:47 PM
All complete.
Looks excellent.
Now, you can't just post that and not update us on how you got the cross pin out.
Old Apr 10, 2013 | 02:00 PM
Allan mine came out with the punchand a BFH no problems. For once something went easy for me.....
Old Apr 10, 2013 | 03:05 PM
Good to know. From looking at mine (during the rebuild) it looks like the cross shaft is all the same OD. Did you by any chance measure to find out? More a curiosity thing for me than anything else.
What is the significance of the copper on that coupler pin? Mine were all steel.
Old Feb 7, 2019 | 12:20 AM
JCMC64's Avatar
JC
Allan , what is correct color scheme on this intermediate shaft? Is yours correct?
Inline has this color scheme, above ( could not move pic to below, how to do that?)
Old Feb 7, 2019 | 10:52 AM
  #31
Jim - it's the color I liked best. Cast metal by Duplicolor. They were probably black from the factory but I like this look much better.
Old Feb 7, 2019 | 11:30 AM
  #32
JCMC64's Avatar
JC
I got Duplicolor Stainless paint that is similar.
yorkman
Jan 11, 2019 08:19 PM
cdrod
16
Feb 26, 2015 09:26 AM
tcarroll
Sep 6, 2012 06:43 AM
dc2x4drvr
May 2, 2011 11:10 AM
scrappie
Feb 13, 2010 04:41 PM
