Front coil spring clocking?
Hello everyone,
I just finished my Winter - full frame off restoration of my 71 Olds Cutlass S post coupe. I replaced everything, body mounts, new control arm bushings (poly), Ball joints, added bigger swaybar, added 1" stock style rear sway bar ( + boxed rear LCA's and added frame triangular braces).
I always hat that issue, that my car is sagging about 1 inch on the left front corner. It did before the restauration and now after it, its the same. I tried everything and im so sick of this issue.
I always thought that the front coil springs are clocked correctly if the end of the spring is sitting in the deepest position of the front LCA. Today, i red in my 71 Chassis service manual, that the end of the coil springs should be BETWEEN the 2 small holes in the LCA's spring pocket. BUT - my LCA's just have one small slot hole in the spring pocket? So where should i place the end of the coil on these LCA's?
I hope someone reds my novel 😁
Thank you for your help, greetings from Austria!
