66 cutlass front coil placement
Old Apr 18, 2016 | 05:50 PM
sortasane's Avatar
I have a 66 Cutlass convertible. I just replaced all of the front suspension except the coils.Everything is tight but I have a rattle on the driver's side.Does the lower control arm have a certain place that the lower end of the spring should sit in? Any help would be appreciated.
Old Apr 18, 2016 | 06:52 PM
Yes there is an inspection hole in the spring pocket. The end of the spring should be close to it. Have you checked your frame to body bushings?
Old Apr 19, 2016 | 05:25 AM
I'm assuming you mean you replaced all the bushings and ball joints, so the springs were out at one point. You probably realize that the ends of the front springs are different. The flat ground end goes up into the frame pocket. This is a difficult installation since it is blind and thus easy to get the spring out of position as you compress it with the lower control arm. Also, as noted, the lower coil needs to sit in the pocket in the LCA at the correct rotational position The pocket is contoured to accept the pigtail of the spring. Your Chassis Service Manual shows this.
Old Apr 19, 2016 | 07:11 AM
Run to Rund's Avatar
Not on a 64-67! Both spring ends are the same (tangential). The end at the top fits into a seat, and there is an inspection hole in the frame pocket under the upper A arm. There also are holes in the lower arm's pocket and the bottom end should be between them, or depending on how an aftermarket spring is made, it can be just past them but still in the pocket. Some coils are up to 2" longer than an integral number of coils, some are a bit shorter than that.
Old Apr 19, 2016 | 07:56 AM
Irregardless, the spring position will not cause a rattle. There is something else wrong.
Old May 15, 2016 | 05:35 PM
sortasane's Avatar
I am going to go ahead and embarrass myself with this one. I did good on the front end. It sounded just like the front until I opened the driver's door. It was the driver side axle bearing. Replaced them and everything is great now except the egg on my face.
Solid Lifters
Aug 6, 2013 05:30 PM
boese1978
Dec 18, 2011 06:41 AM
craftsman1956
Suspension & Handling
Dec 7, 2010 04:59 AM
scott_442
Feb 27, 2009 03:31 AM
68conv455
Feb 20, 2008 02:36 AM
