Frame compression bushings
Old May 2nd, 2019, 11:21 AM
bob provost's Avatar
I have a 67 442 and I'm replacing the frame bushings. However, the kits that are available do not have the compression bushings that are under the rear seat or over the axle. Can you use 4 additional standard bushings? It's a 2 door hardtop. Thanks Bob
bob provost is offline
Old May 8th, 2019, 06:57 PM
Schurkey's Avatar
I replaced a pair of those bushings with bushings secured with bolts and washers on my '68; but that was because the cage-nuts were already installed in the body. No cage nuts...no center bolt.
Schurkey is offline
Suspension & Handling
May 29th, 2019 04:14 PM
dennis_30281
January 5th, 2018 04:28 PM
1966Oldsmobile
September 2nd, 2015 03:00 PM
steverw
October 22nd, 2014 06:56 PM
coppercutlass
June 8th, 2014 11:57 AM
Quick Reply: Frame compression bushings
