Cutlass door fit
Yes, assuming both are hardtops or convertibles. If I remember correctly, there is one internal difference between 70 and 71, which is the side impact beam in the door. This also resulted in a change to the window mechanism. So long as you swap the complete door, there should be no problem.
'71-72 Cutlass doors
Another question for junkyrd dogs, will a '71 fastback HT door fit a '72 supreme convert?
thanks,
I may be doing the same thing, a '71 supreme HT door onto a '72 Supreme convert. My convert door has a dent and I have a mint california door to bolt on. Can I use the glass from the '71 supreme HT door on the '72 convert? Can I swap the '72 convert glass into the '71 supreme HT door?
thanks,
thanks,
tmaleck
August 15th, 2021 08:17 AM
jayleo_4
February 14th, 2012 07:09 AM
