Cutlass door fit
Old Jul 5, 2008 | 08:35 AM
Southern_Hospitality's Avatar
Exclamation Cutlass door fit
Will a 1970 Cutlass SX door fit a 1971 Cutlass Supreme?
Old Jul 5, 2008 | 12:12 PM
Yes, assuming both are hardtops or convertibles. If I remember correctly, there is one internal difference between 70 and 71, which is the side impact beam in the door. This also resulted in a change to the window mechanism. So long as you swap the complete door, there should be no problem.
Old Jul 5, 2008 | 01:27 PM
Cutlass door fit
Thanks Joe, you're the man!
One more thing. The '71 Cutlass SX door is from a hardtop. Can it be modified to fit a '71 Cutlass Supr Convt?
Old Jul 5, 2008 | 01:28 PM
gearheads78's Avatar
car guy
both use the same door
Old Jul 5, 2008 | 02:48 PM
The only difference is that you'll need to transfer the wedge plate from the back edge of the old convert door to the new HT door.
Old Aug 19, 2008 | 11:54 AM
flameorange's Avatar
'71-72 Cutlass doors
I may be doing the same thing, a '71 supreme HT door onto a '72 Supreme convert. My convert door has a dent and I have a mint california door to bolt on. Can I use the glass from the '71 supreme HT door on the '72 convert? Can I swap the '72 convert glass into the '71 supreme HT door?
Another question for junkyrd dogs, will a '71 fastback HT door fit a '72 supreme convert?
thanks,
Old Aug 19, 2008 | 01:21 PM
thanks,
Yes to all of the above.
Old Aug 19, 2008 | 01:58 PM
Cutlass Door Fit
Many thx Joe
BCBigBlock
Body work
Jul 28, 2013 06:09 AM
costpenn
Jun 16, 2012 01:05 PM
jayleo_4
Feb 14, 2012 07:09 AM
ddx77
Jun 24, 2010 10:49 PM
