clunking underneath when car in motion
Old Oct 22, 2022 | 04:55 PM
70sgeek's Avatar
'72 Cutlass ragtop
my 72 CS ragtop started clunking pretty notably underneath when in motion but currently only when I have a passenger in the right front seat - i.e. when I'm driving alone, it doesn't occur. I replaced the transmission mount last night thinking it might have been bad, but it looked great. Entire suspension rebuilt about 6 years ago, mostly all Moog rubber and associated parts. About 15k miles on all since then. Body bushings were replaced probably back in the 90's by a prior owner and the most visible ones looked great at last look. But I will be checking them again.
Feels like the clunking is coming from under the right front or middle area floor towards hump but I suppose it's possibly coming from somewhere else and carrying forth into that area - driveshaft is new aluminum assembly so lighter in weight than the steel tube unit it replaced about a month ago. Eyeballed the motor mounts and they look ok from what I can see - no visibly obvious separation or developing tear issues and the motor only rocks minimally at most to the right on rev up test.
I don't appear to be missing any control arm stops and all components appearing tight with no visible play that I can tell yet.
Any 'why didn't I think of that' ideas on what to check next?
Old Oct 22, 2022 | 05:35 PM
rcorrigan5's Avatar
Randy C.
Exhaust pipe that has some movement to it, perhaps? That's what happened to me with my '69 4-4-2. It had been put together solely with clamps. I had an exhaust man I know look at it and he went through everything, refitting as appropriate and tac-welding all the joints. It made a big difference and....no clunking!
Randy C.
cfair
Suspension & Handling
Jun 6, 2021 01:33 PM
96powerstroke
May 29, 2017 03:10 PM
RetroRanger
15
Sep 16, 2011 03:49 PM
Bunser
Body work
Sep 11, 2009 09:04 AM
silverriff
Aug 19, 2008 10:07 AM
