64/98 has a little knocking from the rear
Old May 23, 2015 | 11:26 PM
Jandk's Avatar
Hi
I have been under the car (in the driveway so far) trying to locate the cause. No luck this time. While considering drive to work, where I have better room to have a look at the car, I thought I would ask you experts here..
When going own the road, useally best at low speed, and ofcause with a little rough/slightly uneven road maybe with a few small potholes in it, I have this slight knock from the rear. The knock is not much, and is only there when then the rear are trying the give me a smooth ride. I guess it could be bush in a controlarm, but what ells could make the rear knock when driving down the road?
If it is a controlarm.....where do I source them for a 64/98, or can I hunt down some from another GM?
Old May 24, 2015 | 01:00 AM
I notice you've posted in the Custom/Aftermarket Suspension Forum. It might help to know what kind of setup you have.
Old May 24, 2015 | 02:18 AM
Jandk's Avatar
Sorry... Actually its a completly standard car.
Old May 24, 2015 | 07:18 AM
Have you checked your body bushings?
Old May 24, 2015 | 08:13 AM
Don R.'s Avatar
Loose or defective rear shock absorber or loose junk in the trunk?
Old May 24, 2015 | 11:11 AM
X 2. Have you had a good look at the shock mounts back there?
Old May 24, 2015 | 02:34 PM
Jandk's Avatar
Good point....
zak0331
May 5, 2014 05:29 PM
Leadfoot
Feb 5, 2014 03:58 PM
GAOldsman
Aug 19, 2011 02:06 PM
OCM
Jan 29, 2011 01:30 PM
oldsdroptop
Jun 2, 2009 07:03 PM
