Name this steering/susp part...
Old May 26, 2015 | 07:56 PM
Napoleon Solo's Avatar
I'm indecisive. Or am I..
Starting the chassis reassembly so I bought all new moog stuff for the steering system, painting them all up to match my frame. Everything seems to be identified and accounted for except this one part. I have a great memory but it's short....
Old May 26, 2015 | 07:58 PM
tru-blue 442's Avatar
Old School Olds
Idler arm.
Old May 26, 2015 | 08:08 PM
nsnarsk65cutlass's Avatar
The part with the threads is idler arm,the part with the two holes is center link,not sure what part you are pointing to.
Old May 26, 2015 | 08:12 PM
As the others said the part with your finger on it is the center or drag link. The other looks like an idler arm but not the same as the other picture. Who's kit is that?
Old May 26, 2015 | 09:19 PM
After posting the pictures I thought there may be confusion. It's not the center link - it's the small part. I have a new idler arm that bolts to the PS frame - unless there is one on the DS side too...I wish I took better pictures. It looks a lot like the idler arm but I dunno...
Eric - are you referring to the box? It\s a complete set of energy suspension bushings. Other than that it's all stock parts painted gunmetal gray.
Old May 26, 2015 | 09:51 PM
The 2 parts in the picture above are not related at all. The bottom one is a typical A body idler arm, the top I have no idea. The drivers side has a pitman arm on the steering box and the top part in the picture again is not it.
Old May 27, 2015 | 11:59 AM
BackInTheGame's Avatar
Red face Part question
I'm drawing a blank on the actual part name, but that arm without the attached bracket (idler arm) bolts to the bottom of the steering box and connects to the center link. Is that the Pittman arm? I received the same thing in my set of Moog parts.
Old May 27, 2015 | 12:06 PM
Old School Olds
I thought pitman arm too, but no way to tell without seeing the hole.
Should be toothed with a keyway if it is.
Old May 27, 2015 | 12:55 PM
His pitman arm should look like this, if you look at the drag link the tapered joint slips into both the pitman arm and the idler arm:
Old May 27, 2015 | 01:01 PM
Old School Olds
^^^Right...What the heck is it I wonder.
Old May 27, 2015 | 02:26 PM
69442C's Avatar
I believe it is the idler arm as something tells me the factory idler arms may have been a 2 piece assembly. I think there may be a bracket that he has that would connect to the ball joint and that bracket will bolt to the frame. The new units come as one piece.
Old May 27, 2015 | 08:42 PM
Funny thing is - I'm sure I have the original idler arm at the shop. It's not the pitman arm either cuz there are no splines. Oh well - I'll start the reassembly and see if makes itself evident.
Thanks for the assistance, regardless.
Old May 27, 2015 | 10:35 PM
4speed455's Avatar
Year and model might help narrow it down.
brownbomber77
Jun 11, 2018 05:39 AM
coppercutlass
Jun 8, 2014 11:57 AM
Bluemeanie
Feb 2, 2013 10:02 PM
Takid455
Suspension & Handling
Aug 31, 2012 06:42 AM
deweirdt
Jul 21, 2009 08:29 AM
