Wheel cylinder question 69 442
Old Nov 15, 2011 | 02:53 PM
Beob's Avatar
For some reason my rear wheel cylinder which only has a couple hundred miles on it is leaking. The local Napa has a couple in stock but they both have different bore sizes, 7/8 and 1". Does anyone know which is recomended for my car or can I use either one?
Thanks, Rob
Old Nov 15, 2011 | 03:49 PM
svnt442's Avatar
Front disc brakes take the smaller bore and front drum use the larger bore cylinders.
Old Nov 15, 2011 | 04:34 PM
Beob's Avatar
little confused, but I think your saying front drums use the larger bore so the rear drums would use the smaller bore at 7/8.
Old Nov 15, 2011 | 05:59 PM
olds1968's Avatar
member
no if your car has disc brakes the rear drum will take the smaller bore cylinder and if it has drums up front it takes the larger bore in the rear
Old Nov 15, 2011 | 06:13 PM
Beob's Avatar
Now I understand. The car now has front discs, so I will use the smaller bore.
Rob
EightballZ
Brakes/Hydraulic Systems
Jan 17, 2011 12:37 PM
Gary's 2 442-S
Apr 25, 2010 05:29 PM
ctrain22
May 27, 2009 06:58 PM
rustyold66
Aug 14, 2008 07:34 PM
