Rear Brake Line
Rear Brake Line
Looking at redoing my brake lines on my 69 Cutlass S. On the 69 there is a point where the hard line connects with a soft line at the rear cross member. Then this flexable line T's at the axle. The T junction actually bolts to the axle. So in replacing this flexable T section any suggestions. I checked Fusicks and they have the T junction but it doesn't have the option to bolt down. I can replace the T and Cut the Bolt loop of the old and weld to the new but wanted to see what others have done.
I don't recommend welding the T piece, the heat might distort the threads giving you a mystery leak.
Unless you want complete originality I think you can buy a generic T piece with a bolt hole at a good auto parts store.
Roger.
Roger.
Big Thanks
Thanks guys. It wasn't to cold this past weekend so i was able to get the part and get about half of the brake lines ran. Now waiting on the brackets and perportioning valve from the junk yard and i can finish out the brakes.
Del70
Dec 7, 2025 02:13 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
