Rear Brake Line
Old Nov 22, 2011 | 05:07 PM
mcutlass1969's Avatar
Rear Brake Line
Looking at redoing my brake lines on my 69 Cutlass S. On the 69 there is a point where the hard line connects with a soft line at the rear cross member. Then this flexable line T's at the axle. The T junction actually bolts to the axle. So in replacing this flexable T section any suggestions. I checked Fusicks and they have the T junction but it doesn't have the option to bolt down. I can replace the T and Cut the Bolt loop of the old and weld to the new but wanted to see what others have done.
Old Nov 23, 2011 | 09:19 AM
rustyroger's Avatar
'87 Delta 88 Royale
I don't recommend welding the T piece, the heat might distort the threads giving you a mystery leak.
Unless you want complete originality I think you can buy a generic T piece with a bolt hole at a good auto parts store.
Roger.
Old Nov 23, 2011 | 11:10 AM
thanks. I got ahold of advanced auto parts and they actually could get the piece. i was kinda amazed due to typically auto part stores now a days can't get parts for older cars.
Old Nov 23, 2011 | 12:02 PM
Rickman48's Avatar
It's not exclusively for the 'older' cars - just the same part all these years for rear-drive GM's!
Old Nov 23, 2011 | 04:36 PM
Run to Rund's Avatar
The correct flex liine will have a t-terminal swaged onto the hose. There will be a bolt hole plus two brake line female fittings. One such line is F79997 or Centric 150.62387.
Old Nov 28, 2011 | 05:28 AM
Big Thanks
Thanks guys. It wasn't to cold this past weekend so i was able to get the part and get about half of the brake lines ran. Now waiting on the brackets and perportioning valve from the junk yard and i can finish out the brakes.
Del70
Dec 7, 2025 02:13 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
davepnola
Dec 2, 2010 09:00 PM
Flye
Jul 31, 2009 04:03 PM
68conv455
May 20, 2008 02:03 PM
