Squeaky / Creaky brake pedal
Old Apr 7, 2026 | 08:22 PM
1969Hurst's Avatar
I guess they better word is 'creaky'.
When I step on the brake pedal its a creaky noise coming from the pedal area in/behind the dash. No noise related to the brakes itself, pads/rotor/caliper, etc.
The brakes appear to be functioning as expected but I get the noise with the travel of the pedal.
In looking at the service manual, 5-110, seems there is a bolt, a spacer and a couple of bushings mainly holding the brake arm to the bracket assembly.
Has anyone had anything similar? Is they any point of lubrication that can be applied? Seems there is a bushing on either side of the arm, can those be getting worn or have worn down?
I don't relish crawling up under the dash but will have to start poking around.
Old Apr 8, 2026 | 03:16 AM
Yes, My 71 Cutlass does it. It is in the vacuum booster. About 7 yrs ago I also had a Vista Cruiser which needed a vacuum booster, so I decided to buy a new nice looking booster for my Cutlass- then use the one out of Cutlass on the Vista. After swapped out noise stopped on Cutlass and was now squeeky on Vista. Now its been a while and squeek is coming back on "new" booster on Cutlass. Doesn't seem to bother anything- just squeeky/creaky.
Old Apr 8, 2026 | 03:44 AM
Bfg's Avatar
Bfg
I had the same noise on my 65 Cutlass, it also turned out to be the brake booster
Old Apr 8, 2026 | 05:35 AM
Check the function of your emergency brake too. The emergency brake on my 71 98 wasn't working so I sprayed the mechanism liberally with penetrant and used an old toothbrush to scour the parts.
Old Apr 8, 2026 | 07:05 PM
Jeff, creaking is frequently the return spring on the brake pedal. Lube on the holes where the ends hook into is easy to try. Failing that, I'd replace the plastic bushings.
Old Apr 8, 2026 | 07:54 PM
1969Hurst's Avatar
Thank you all for the suggestions!
Seems to make most sense to go easy to difficult if needed.
I'll lubricate what I can... jam what I can at the bushing area...
In lieu of that investigate the bushings for replacement and it all else fails, think about the booster, even though it is in nice plated condition.
I'll try to crawl under there and try to actuate the pedal myself which it prob a next step as well for investigating the noise.
I may just unbolt the seat to give my back a saving grace.
Tancuda
Brakes/Hydraulic Systems
Apr 28, 2024 03:32 PM
cjsdad
Dec 11, 2023 10:13 AM
sgolds
Jun 9, 2021 05:42 PM
servexcell
Jun 11, 2018 07:20 PM
cutlassjoe
Oct 21, 2010 07:56 PM
