Brake pedal height...
Old Apr 28, 2024 | 12:07 PM
Tancuda's Avatar
Hi guys, can't find spec for brake pedal height, any dimension please ?
Old Apr 28, 2024 | 01:22 PM
At rest, the inside rod/clevis should be adjusted so the pedal is against the upper stop and the pin can be inserted easily.
Old Apr 28, 2024 | 01:40 PM
Since you failed to indicate the year & model of vehicle we can't make predictions based on non information. None-the-less clevis top hole manual brakes bottom hole power brakes.
EDIT: You have the 1971 4-4-2 you asked about wire gauge? OK, top hole manual brakes, bottom hole power brakes. Still, always indicate year & model your thread pertains to many people have more than one vehicle - nothing served by guessing.
Old Apr 28, 2024 | 02:18 PM
Tancuda's Avatar
Sorry for this, yes 71 442 power brakes, and in bottom hole.
Like oldscutlass mentionned, " the inside rod/clevis should be adjusted so the pedal is against the upper stop" , I only see the stop light switch, still looking for the upper stop..
Thanks guys
To de-mystify my previous post - in which case Eric is correct regarding the mount point of the brake assembly, I was thinking of the clevis pin location on the brake assembly itself (not the bushing mount plate). Hopefully this will clarify.
Old Apr 28, 2024 | 03:11 PM
Tancuda's Avatar
Thanks for the diagram Vintage Chief.
Old Apr 28, 2024 | 03:32 PM
cjsdad
Brakes/Hydraulic Systems
Dec 11, 2023 10:13 AM
sgolds
Jun 9, 2021 05:42 PM
griffey57
Apr 20, 2021 10:02 AM
servexcell
Jun 11, 2018 07:20 PM
cutlassjoe
Oct 21, 2010 07:56 PM
