Original MC or Not??
Old Aug 31, 2019 | 12:32 PM
dougherp's Avatar
Phil D.
Can anyone help me to see if the MC I have had in the basement for 30 years is most likely my original one -1971 442, I can't remember. In the picture it looks like the part number (5470409) and the date code (D12). I can't find the part number in my parts cat. What does the date code correspond to?
Old Aug 31, 2019 | 02:23 PM
scrappie's Avatar
I think there should also be BE stamped on front? Not sure about other numbers?
Old Aug 31, 2019 | 03:24 PM
Hairy Olds's Avatar
Shoveling Snow
Need more photos.
Old Sep 1, 2019 | 08:05 AM
dougherp's Avatar
Phil D.
Thanks, I'll try and post some today
Old Sep 1, 2019 | 12:26 PM
VC455's Avatar
Barely Registered
The casting number is often different from the part number.
As Scrappie intimates, the stamped code may be your best identifier.
Old Sep 3, 2019 | 10:18 AM
RocketDevo's Avatar
The casting number is correct.
As scrappie has said the two letter code stamped on the top front should be "BE"
All 1971-72 A body power disc brake cars were the same.
As VC455 said the part number on the box is usually different than the casting number on the part.
Hope this helps.
costpenn
Feb 1, 2018 03:34 AM
Zr1bandit
Dec 10, 2016 11:33 AM
brandon reynolds
Feb 28, 2016 06:23 PM
DEL663
Nov 22, 2015 05:08 AM
bobb
Oct 8, 2010 03:40 PM
