full size rear discs !!!!!!!
Been looking for some time for any kind of rear brake kit for my 74 delta 88.With the mods I've done to the powertrain,brakes are a necessity. My neighbor has a 2002 gmc safari van 4x4 that I've done brakes on a few times and haven't chucked the old parts. As it happens the bolt pattern is 5x5 . The front rotors are a perfect fit for the backspacing and the fit of the hub/axle. I will be making my own caliper mounting brackets and using aftermarket 2 piston calipers with drilled rotors,and try several pad configurations. So for those of you who appreciate a REAL car with room, and need the stopping power try this mod.
Oldsragger
Brakes/Hydraulic Systems
January 26th, 2015 05:28 AM
txrob779
Drivetrain/Differentials
15
February 26th, 2014 11:08 AM
lshlsh2
February 3rd, 2013 08:40 AM
Aceshigh
June 24th, 2010 09:05 AM
