full size rear discs !!!!!!!
Old Apr 5, 2009 | 06:59 PM
71 delta88guy's Avatar
Been looking for some time for any kind of rear brake kit for my 74 delta 88.With the mods I've done to the powertrain,brakes are a necessity. My neighbor has a 2002 gmc safari van 4x4 that I've done brakes on a few times and haven't chucked the old parts. As it happens the bolt pattern is 5x5 . The front rotors are a perfect fit for the backspacing and the fit of the hub/axle. I will be making my own caliper mounting brackets and using aftermarket 2 piston calipers with drilled rotors,and try several pad configurations. So for those of you who appreciate a REAL car with room, and need the stopping power try this mod.
Old Apr 5, 2009 | 07:57 PM
Glad to hear this worked out for you. Other rear disk options with 5x5 bolt pattern rotors are the 80s vintage Eldos and the 91-96 Caprices.
Old Apr 6, 2009 | 11:14 AM
The Stickman's Avatar
What diameter are the rotors front and rear?
Old Apr 6, 2009 | 12:08 PM
the fronts are stock 74 delta 88. the rear are I believe 11 inch vented.like 10.91 inch. almost exactly the same diameter as the backing plate were the rear drums used to be.
Old Apr 6, 2009 | 01:56 PM
Post pics if you can.
Old Apr 6, 2009 | 08:24 PM
Danny Wiseley's Avatar
How are you going to rig up a parking brake?
Oldsragger
Brakes/Hydraulic Systems
Jan 26, 2015 05:28 AM
txrob779
Drivetrain/Differentials
15
Feb 26, 2014 11:08 AM
lshlsh2
Feb 3, 2013 08:40 AM
Aceshigh
Jun 24, 2010 09:05 AM
Natas
Oct 15, 2007 11:41 AM
