Cany anyone identify these front disc brakes?
Old Jan 30, 2026 | 12:52 PM
wheelmanolds's Avatar
My 67 442 has aftermarket single piston front disc brakes (MotorWheel Centrifuse rear drums). I haven't been able to identify them using the rotor part number (5514B-2). It's 10.5 inches, one piece rotor/hub. One pad clips to the outside of the caliper, the inside pad floats with a single clip at the bottom. The pad part number is a partial which a Chevy part guy said might be from late 80's truck. I bought some for a C1500; they were close but not quite right. No part number on the caliper other than a "T" on both and "R" on one and "L" on the other. The pads still have meat and the rotor was able to be turned. So I'm good for now but at some point will need to take action. I'm guessing everything came in a kit (including spindles and mounting plate) made for GM as I have SuperStock wheels (more on that in a future post). Any ideas?
Old Jan 31, 2026 | 05:16 AM
oldoldss's Avatar
Duralast brand (Auto Zone) has a rotor part number 5514. The size seems similar. Maybe check into that and see what it fits then search pads for that. Your pads have MD215 printed on them. There are Duralast MKD215 pads that look a lot like yours.
Old Jan 31, 2026 | 07:44 AM
nicks1966's Avatar
Look up a brake caliper form a 1987 to 1993 cutlass cruiser
Old Jan 31, 2026 | 01:55 PM
Thank you oldoldss. I actually bought these exact rotors (and another, identical set from NAPA); turns out the hub hole is too large for my spindles and the "hat" is too tall. The corresponding pads fit my caliper but they are slightly wider than what I have and the caliper/pads wouldn't fit over my rotor.
6498HO4speed
Brakes/Hydraulic Systems
Jun 28, 2024 05:36 AM
Chuxter
Jun 27, 2023 06:37 PM
VI Cutty
Feb 8, 2023 06:33 PM
smparr
Apr 16, 2021 05:36 AM
Joeypete
Jul 29, 2009 01:25 PM
