Both reservoirs depleting at equal rate, bad master cylinder?
Old Mar 17, 2025 | 01:05 PM
illumined's Avatar
1978 Ninety Eight
I noticed the last couple of outings the brakes getting softer and the pedal travel gradually increasing. When I opened it up I saw the front reservoir was significantly lower than before and the rear reservoir was almost gone, it looks like they've been leaking at about the same rate. If this is the master cylinder I would be very disappointed as I got it rebuilt at Karps and paid good money for it. Thoughts?
400 miles of driving.....
Old Mar 17, 2025 | 02:03 PM
Now all you need to do is see where the leaks are.
Old Mar 17, 2025 | 06:18 PM
Sugar Bear's Avatar
Look for leaks, follow the lines, hoses, pull the wheels, unbolt and look at the back of the master cylinder. If that much fluid did go into the booster that is a problem.
Old Mar 17, 2025 | 07:30 PM
illumined's Avatar
1978 Ninety Eight
Think we found the problem, one of the hard lines going from the master cylinder was loose. I'll know for sure later when I get it back on the road but pedal travel so far is much better.
Old Mar 18, 2025 | 06:49 AM
Hopefully you resolved the leak. 🤞
Old Mar 18, 2025 | 06:58 AM
jaunty75's Avatar
Will this solve your problem? A single leaking hard line should have caused ONE of the two reservoirs to drain, not both of them. That's the whole point of a dual master cylinder system. If it's not the MC itself, you apparently should be looking for TWO leaks. You've found one. Keep looking!
Old Mar 18, 2025 | 07:01 AM
This ^^^^^^^^^^^^
Old Mar 19, 2025 | 10:48 AM
illumined's Avatar
1978 Ninety Eight
I did, found nothing else. What you're saying makes sense but I'm not sure where else to look, everything else checked out so far. At this point the best I I can do is get it back on the road and see which one is still dropping to narrow things down more.
Old Mar 19, 2025 | 10:49 AM
jaunty75's Avatar
I think that's your plan. Fill both reservoirs, drive it a bit, and see what happens to the fluid levels.
Old Mar 19, 2025 | 11:17 AM
stan 65 cutlass's Avatar
check under your drivers side floor mat, if the leak is up under the dash
Old Mar 19, 2025 | 12:00 PM
If it's a bad master, and you have power brakes, it will barf on the booster. or in the booster. If you don't, it will barf on the firewall/ the floor inside the car.
woodeye47
Brakes/Hydraulic Systems
May 31, 2023 07:43 AM
ilandtime
Mar 10, 2014 09:25 PM
Nighthawk
Dec 24, 2013 01:41 PM
al714
15
Sep 20, 2013 08:06 PM
Mr Shifty Sidney
Jun 12, 2013 12:06 AM
