89 cutlass supreme rear drums
hey, i have a 86 cutlass supreme brougham with a 307.
a brake line went on we a couple days ago and i just replaced the line. When i went around the back to bleed the rear i noticed the drums dont seem to have any bleeders.
is this normal, if so where would i be able to bleed them form?
thanks,
Adam
thanks,
Adam
thanks,
Adam
thanks,
Adam
I not didn't mean drum brakes don't have bleeders. When read the tread it sounds like he saying he thinks the drum has bleeders. I sure he didn't mean that but that is how it reads. That is why I said the wheel cylinders has a bleeder. Brake fluid goes to the wheel cylinder from the master cylinder. When you push on the brake pedal. The wheel cylinder pushes the brake shoes out and makes contact with the drum stopping the car. The drum is only one part of the brake not the whole so the drum doesn't have bleeders the wheel cylinder does. Each drum brake has it own wheel cylinder.
I didn't mean drum brakes don't have bleeders. When read the read it sounds like he saying he thinks the drum has bleeders. I'm sure he didn't mean that but that is how it reads. That is why I said the wheel cylinders has a bleeder. Brake fluid goes to the wheel cylinder from the master cylinder. When you push on the brake pedal. The wheel cylinder pushes the brake shoes out and makes contact with the drum stopping the car. The drum is only one part of the brake not the whole so the drum doesn't have bleeders the wheel cylinder does. Each drum brake has it own wheel cylinder.
I have not done as much with the front wheel cars as I have with the rear drive ones.But still all cars have four bleeders though when they get old they get stuborn.I have done several things to get by that include loosening the line to bleed the brakes as well as changing bleeder screw,new wheel cylinder and using thrust to get it loose from rusts grip.
I have also snapped a few bleeder screws as well you can imagine things that are said when that happens along with the aggervation of the job to begin with.
thrust is penetrating oil to get those rusted bolts loose.ehh wd 40 was just a reference maby not one of the better ones.I am finding there are uses for household items that take the place of buying products you don't relly need.For instance you can use pam or cooking spray to get squeeky door hinges on doors or cabinets to stop sqeaking.
skaboy 40
Brakes/Hydraulic Systems
Apr 12, 2007 08:22 AM
