Door skin options
Old Jan 15, 2019 | 03:21 PM
scrappie's Avatar
Door skin options
1970-72 cutlass/442
Apparently production on the reproduction door skins and also the lower reproduction patch skin has been discontinued.
I don't need a whole skin even but I was thinking of a lower patch to work with. No matter who I call, nobody has them.
What are some options besides rust free doors? Is fabrication possible? I was thinking the Buick skylark lower section may be the same?
What would you guys do?
Old Jan 15, 2019 | 03:31 PM
2blu442's Avatar
Would a 4 door have a large enough piece if you just need a patch of doorskin?
Old Jan 15, 2019 | 04:54 PM
scrappie's Avatar
I have some rust on the bottom edge pretty much the whole way. I was thinking of a piece maybe a couple inches high across the bottom on a two door. Thx tho
Old Jan 15, 2019 | 08:22 PM
coppercutlass's Avatar
Chevy budget Olds powered
Have you called the warehouses . Like parts place or tamraz. I bought door skins for my 72 2 years ago. They actually where not bad. gauge was a little thinner but not a deal breaker for me.
Where is the door needing repair. A picture is always helpful. As a bodyman anything is for the most part repairable it just comes down the skill , time, patience and or funds. You can always eliminate one of those factors but will have to lean on one more so than the other depending where you stand haha.
Old Jan 16, 2019 | 04:22 AM
scrappie's Avatar
Thx, your thread on door skin replacement kind of motivated me I first contacted Tamraz and they told me parts have been discontinued so Ive been looking at options. The skins are pretty good other than some rust on bottom edge but no holes. Rust on the fold and underneath the fold is what I want to address. If I unfold the bottom edge to expose the rust I pretty much destroy that edge so I wanted to possibly cut it out, media blast any rust and replace with a new piece. I realize with the right metal tools (wheels, brakes) and skill this could be done but its critical door gap and possible contour depending on how far up. It seems pretty flat a couple inched up then starts to curve so Im thinking if I stay below the contour, it will be easier. Getting the fold right will be the challenge for me. I thought it may be best to have a replacement to work with rather than a complete fabrication. This will be a learning process either way.
Old Jan 16, 2019 | 05:24 AM
It's kind of the perfect spot to learn. If it's in ok shape id say repair it and have fun learning. Keep your initial cuts as small as possible . Make patch templates from thin posterboard or even poster cards . There is a couple of ways to make a home made break Google will yeild tons of results .
Old Jan 16, 2019 | 05:28 AM
Jegs is showing a LH and RH door skin for 325 a pop. About 75 per piece more than the parts place.
Old Jan 16, 2019 | 05:38 AM
rickman's Avatar
Options. I haven't used any of these and not sure if these places have them but...Sherman Parts is showing lower repair - https://www.shermanparts.com/ecat/ba...***&year=1972; Goodmark whole door skin - https://www.goodmarkindustries.com/c...in-outer.aspx; lower repair - https://www.rustrepair.com/68-CUTLAS...R-647031L.HTM; Have you checked Fusick?
Old Jan 16, 2019 | 06:41 AM
scrappie's Avatar
Jegs out of stock, Goodmark out, Autobody specialties checked a bunch of places for me and they can't get either, I spoke to Fusick yesterday also and they can't get anything. Everywhere I check says discontinued with no further info.
Old Jan 16, 2019 | 07:25 AM
It showed in stock on my computer but then again i didnt add it to cart. Try patching it up keep it small.
Old May 24, 2019 | 05:54 AM
OldSoldier's Avatar
Car Nerd
Scrappie, I'm not sure if you are still looking for door skin patches or not, but www.millsupply.com just shipped me both sides for my '71 yesterday.
Matt
Old May 31, 2019 | 06:02 PM
scrappie's Avatar
Thx Matt, I did find some but good to know other resource
scrappie
Body work
Dec 7, 2018 07:10 AM
oldsrocket88
Alero
May 13, 2015 03:37 AM
Eddie Hansen
Body work
Dec 3, 2014 08:38 AM
dallaire1
Body work
Apr 8, 2009 04:42 PM
J-(Chicago)
Jul 20, 2007 08:25 PM
