Fender to hood arch
Old Dec 26, 2022 | 11:56 AM
70convert's Avatar
Fender to hood arch
Seems the arch on the fender doesn't match the hood on one side. After going crazy trying to correct I finally noticed the space where the crumples are is wider on the fender with the non matching arch. Looks like it was welded at a different point. I'm installing on my 70 supreme. I bought the donor fender that was off a 442. Is it possible the hoods curve are different. Not sure if this makes any sense but hopefully it does too someone. Thanks for looking.
Large gap under crumples
Smaller gap under crumples are matching curve with hood
Old Dec 26, 2022 | 01:07 PM
No, the hoods are not different, nor are the fenders. Those are 71-72 fenders with the crumple dimples, but that doesn't matter either. I assume you're installing an aftermarket O.A.I. hood?
Old Dec 26, 2022 | 01:11 PM
Funkwagon455's Avatar
Very normal and typical for OAI hoods.
Old Dec 26, 2022 | 02:04 PM
70convert's Avatar
Not installing OAI hood. Original supreme hood.
Old Dec 26, 2022 | 03:03 PM
Sorry, I made a bit of an assumption there. I’ve never had issues with the arches on factory steel hoods. I would suspect that if there was a misalignment that it would be on the hood side though.
Old Dec 26, 2022 | 07:05 PM
70convert's Avatar
I thought the same thing until I measured the gap below the crumple zone which is greater than the other fender side that matches the hood curve.. Not sure I'm explaining this correctly but there is definitely a different in the 2 fenders
Old Dec 26, 2022 | 07:14 PM
If you could source a different fender for mockup, you could find out pretty quickly. Anyone local who could loan one to you for an afternoon? Or perhaps you have a spare?
Old Dec 26, 2022 | 08:18 PM
70convert's Avatar
I thought the same thing until I measured the gap below the crumple zone which is greater than the other fender side that matches the hood curve.. Not sure I'm explaining this correctly but there is definitely a difference in the 2 fenders
Old Dec 26, 2022 | 08:21 PM
70convert's Avatar
Unfortunately no spare. May need to find another for comparison and or purchase.......again
Old Jan 21, 2023 | 08:40 PM
Post70's Avatar
Sounds like you identified the problem which is half the battle. Could you drill out the spot welds in the area that doesn’t line up and then reweld them after you reshape the fender to match the fender?
Dustin
Carsick
Sep 13, 2022 03:21 AM
sheltonoil
Body work
Mar 13, 2017 01:00 PM
KZ442
Nov 27, 2012 03:48 PM
oldsguybry
Jul 11, 2011 04:13 AM
johnnybondo
Feb 12, 2008 05:51 AM
