68 DS remote mirror, trying to install
Old October 1st, 2020, 08:59 AM
boese1978's Avatar
I'll get some pics up later. I got from a fellow member here a mirror per the subject line. Trying to install on my Convertible which has the factory holes for mounting ( since I bought the car it had a cheap screw on mirror) , the mounting area is distorted from the PO installing the cheapo mirror. When I place the remote mirror in place it sits so as to hang over the window channel so you would not be able to roll up the window with the mirror installed. Is there a difference between a convertible mirror and a hardtop mirror? Anyone have a picture of a 68 door with the mounting holes showing? Is it going to be possible to massage this small area back to "flat"? although Im not convinced that either will give me enough room to mount it. Pretty sure the car originally had the remote mirror as the chrome **** surround is installed in the door panel. Any thoughts or suggestions are appreciated!
boese1978 is offline
Old October 1st, 2020, 10:00 AM
allyolds68's Avatar
It sounds like a 70-72 mirror, I know they are slightly different and the difference is in the angle of the top of the door where it sits
allyolds68 is offline
Old October 1st, 2020, 10:28 AM
Randy C.
rcorrigan5's Avatar
What Mike said. Although they look very similar, the 68-69 remote DS remote mirror is different than the 70-72 DS remote mirror. The 70-72 mirror is mounted at a "steeper" angle because the door side on a 70-72 is different than that of a 68-69. A 70-72 mirror mounted on a 68-69 door will definitely interfere with the driver door window.
Randy C.
rcorrigan5 is offline
Old October 1st, 2020, 01:54 PM
boese1978's Avatar
Randy C.
thank you for the reply’s, I’ll find out which mirror I have.....
Old October 1st, 2020, 05:37 PM
72 Olds CS
RetroRanger's Avatar
heres a pic of a 68 mirror
https://classicoldsmobile.com/forums...mirror-132852/
the 70-72 base is at more of an angle the 68-69 is more horizontal
here is a 70-72 one
https://classicoldsmobile.com/forums...ruiser-143304/
RetroRanger is offline
Kajun442
January 2nd, 2021 05:47 AM
My2nd 69 442
November 14th, 2017 05:20 PM
My2nd 69 442
August 13th, 2017 06:23 PM
Octania
April 11th, 2013 09:07 AM
Gamblin Jones
January 31st, 2012 10:18 AM
Quick Reply: 68 DS remote mirror, trying to install
