67 cutlass convertible trunk pan
Old Aug 26, 2020 | 11:22 AM
Tom's Avatar
Tom
Is the trunk pan in a 67 cutlass the same as chevy, buick pontiac? Looking to get a full trunk pan and all I've found online is chevelle.
Old Aug 26, 2020 | 12:02 PM
Oldsmaniac's Avatar
The same but make sure you get a full pan if needed, some come up short. The 3 piece ones are easiest to install.
Old Aug 26, 2020 | 12:26 PM
RandyS's Avatar
They are, but there is a LOT more welding involved.......
Old Aug 26, 2020 | 08:42 PM
Tom's Avatar
Tom
I talked to someone at AMD about their pans. They dont have one specifically for a Cutlass. He wasn't sure but he thought the olds pan is a bit longer than the Chevelle. I got this 67 Cutlass convertible as a basket case. At some point it was hit in the rear so the back brace needs to be replaced. A couple rust holes here and there and weak in other spots. Might as well replace the whole pan. I'm probably the 3rd or 4th person that's worked on this car. Probably be a couple more owners before it ever get finished. Thanks for the help.
Old Aug 29, 2020 | 10:54 AM
68442's Avatar
They are the same up until you get to the back where it rises up to the latch and tail panel. This area is unique to all the individual makes. I have used the chevelle pan on many 1pc replacements in Cutlass's and transitioned at that tail portion.
Old Sep 5, 2020 | 07:05 PM
2Olds4U's Avatar
Majored in rear tire demo
I bought one for a 67 on E-Bay about 8 years ago. It was perfect in every respect to original. I saved the tag but now can't find it. It ran about $600 shipped with braces, etc. I see what looks like the same one on OPGI, but as everyone knows, they absolutely kill you on shipping anything larger than a light bulb. It is here.
Old Sep 5, 2020 | 07:58 PM
Run to Rund's Avatar
I have a complete body shell for a 67, a 2 door sedan, but not close to you--it is in Vegas. Good luck with your project.
Old Sep 19, 2020 | 06:25 PM
Goldiewilson4mayor's Avatar
Goldiewilson4mayor
1967 Cutlass Supreme Floor
order from Jegs they carry Amd sheet metal and shipping is cheap $99 TRUCK FREIGHT
Old Sep 22, 2020 | 10:40 AM
seanm12's Avatar
Tom, check out thepartsplaceinc.com . They are in Dekalb, IL. Shipping to you might not be bad, or maybe you could drive there. You'll have to call to talk about shipping options.
Old Oct 5, 2020 | 07:10 PM
6D7 442's Avatar
I bought a 7 pc kit from Jegs for my ‘67. It was more welding, but I didn’t know if a full trunk floor would fit through the trunk lid opening. 1 pc. might be more for a frame off.
kevdz79
Aug 8, 2022 07:06 AM
AzChevs
Oct 19, 2014 09:03 PM
Hawk1061
Body work
May 27, 2013 02:28 PM
Ranzan
Jan 23, 2011 04:07 PM
Thuffner3
Dec 31, 2007 07:03 AM
