Product Review- Aftermarket RH MIRROR 68-72
Old Apr 6, 2013 | 11:30 AM
Octania's Avatar
One expects lower to much lower quality from aftermarket parts. There is nothing like NOS factory parts, which is why folks are willing to pay.
Friend of a friend needs a '68 Big Car RH mirror. Friend says "RH mirror for a '68" to me. I go find one:
http://www.ebay.com/itm/140472257260...84.m1439.l2649
and buy one. I expect for dirt cheap to have substandard quality but initially pretty and functional part that can be made to fit with some effort.
Seller wants to know which of the 4 types to send. Now, I had stuck in my memory that due to the shape of the door where the mirror mounts, there are AT LEAST 2 types- mainly regarding the angle that the stalk forms relative to the base, when viewed from front or rear- along the car's for-aft axis. One type mirror [68-9] has a stalk protruding at a right angle [90 degrees] from the base. The other type [70-72] has more slope to the door panel at that point, so the stalk to mirror base angle is more like 60 degrees, with the stalk leaning more upward.
Thus, if you try to put a 70-72 mirror onto a '68-9 door, the higher-tilting stalk puts the mirror head ON the window glass. Not good.
So, anyhow, the seller offers all 4 types- 68-9 vs 70-72 & LH vs RH. Just specify what you want. OK... what do I want?
NOW comes the info from the FOAF that it's NOT A CUTLASS but a Big Car.
GRRRRRRR....... AFTER I make the purchase.
OK, ask around, what fits what? I vaguely recall learning years ago that a 70-72 F85/ Cutlass/ Vista/ 442 base is the same-ish as the 68-9 big car..... right?
No. Experts on the internet say that the PN manual shows all 68-9 models [exc. Toro.] share the same PN mirror. This I verified, and so now we know that what I need is a RH 68-9 mirror.
This info is related to the seller. It took a week or so to iron out this detail, what with travel, work, and home life going on also.
"send me a '68-9 Olds [exc. Toronado] RH mirror" I says.
What shows up in the mail?
"Mirror, Outside 1970-72 Cutlass/442 Right SELECT
CTL9068
[barcode]
*CTL9068RH* "
says the box. The mirror bears the 60 degree stalk to base angle. I actually went thru the gymnastics required to measure this angle with some precision. Box's PN Label says "CTL9068RH" - Why in HELL you would put "68" into the PN of an item that DOES NOT FIT a 1968 model is beyond me?! Shtuff like that only leads to confusion, as we see. If I made up PN's things would make sense. But, I digress...
Well, let's test-fit this thing to a '68 W30 in the garage. PN manual says, and I believe it, that if it fits the F85 line, it will fit the Big Cars too. And, a W30 is just a glorified 442 which is an enhanced Cutlass which is an improved F85.
OK, let's remove these base screws. 3/32" hex I believe.
One is tight. SO TIGHT that the hex key strips the screw's hex recess.
WTH? I expected crappy parts but damn.
OK, bearing in mind that this POS is being returned and I would like to put no marks on it... I remove the screws by gripping the round round head. Sheeesh. Turns out, the screws are SO poorly made, they have begun oxidizing already- God forbid they apply a drop of GREASE at the factory ya know... for something that is expected to live in the outdoors weather... So the screws were basically rusted in place, on a NEW part that has never seen the weather outside of its box in a warehouse and shipping container from China. Grrrrrrr........
Place mirror on door to find that indeed the incorrect stalk angle precludes use on the '68-9 models [exc. Toronado perhaps]. Mirror would hit the window. ALSO, there is a pronounced concave CURVATURE to the door panel at this point, and the mirror base DOES NOT have this curvature, so at best the mounting would be iffy and leaky. FURTHERMORE the factory mirrors typically have a little tang protruding down into the hole thru which your round-round screw head must pass, which prevents the mirror from sliding over to where the screw heads could escape, unless you loosen the screws quite a ways, like 3-4 turns. This prevents the mirror from falling off to its ruin if the screws are just a little loose. The POS "OPGI" mirror does not bear this feature, of course. A minor but not insignificant detail.
Place RH POS mirror next to real factory RH mirror on other W30 in the garage. photo the differences.
Go to put POS screws back into POS mirror to find that the one feels stripped. STRIPPED?! It is brand new, and never did anything but one removal of screw from hole... well it _was_ oxidized in place a little... Closer inspection reveals there might be enough threads to hold OK, MAYBE, but the base is actually so poorly made that there is a cavity where some of the threads should be, so the first 3-4 threads are nut full, and are pretty useless, even before the oxidation ceremony.
Chrome plating on the exterior seems adequate, but it appears pretty weak on the underside of the base.
The factory mirror came with a TEMPLATE- a piece of paper to lay on the door and place the holes properly. This mirror came with no clues at all. Honestly, how tough can it be to produce a 4x20" piece of paper and include one with each mirror? That's just weak. Forces hours and hours of work onto the installer- rather that one person doing that ONE time, and then sharing that clue with all buyers by way of an included template... or at LEAST an instructional sheet. Fail.
Bad craftsmanship / Quality Control.
So, now what?
Message sent to epay seller stating that the wrong mirror was sent. I would expect them to send the correct one and pay for return shipping of the wrong one. The buyer is willing to accept a reproduction part, with all its shortcomings, so that should not be an issue once we get the right part here.
I did want others to be aware of just how poorly these items are made though.
Will update as the story develops.
Old Apr 6, 2013 | 12:10 PM
z11375ss's Avatar
Senior Moment Member
I ordered from year one and I got the same setup w/ the bad screws etc. I ended up using screws from an original mirror. It was my only choice. The "new" ones stripped out just like you said.
Old Apr 6, 2013 | 03:44 PM
Mike77's Avatar
And buying their crap only encourages them to make more! Send it back for a refund. Get a OEM from a yard and clean it up.
Mike
Old Apr 7, 2013 | 07:23 AM
z11375ss's Avatar
Show me the boneyard that has this mirror and I will be there asap. There are none around here like that. Even in the day the good stuff got stripped next to immediately. My point being, if you buy a mirror and expect a quality repro and get junk, it ruins your day to say the least.
Old Apr 7, 2013 | 10:46 AM
RetroRanger's Avatar
72 Olds CS
You'd think there would be a market for quality aftermarket parts ? Wait I know there is people buy thorntons hoods and those fit that description by all accounts. Some after merket stuff is certainly acceptable quality as well,it's just the cheap crap (like it sounds like this mirror was ) that doesn't deserve to be bought (or sold) at any price.
I know I would rather buy something nice for more $ or buy a less than perfect used GM part rather than have an ill fitting POS barely hanging on the side of my car.....
Old Apr 7, 2013 | 02:28 PM
442mark's Avatar
Doesn't Fusick produce a quality mirror for these cars? It's a damn shame that companies like opgi & year one turn huge profits year after year selling boat loads of chinese crap like this. They are the walmarts of the auto restoration industry.
Old Apr 7, 2013 | 02:40 PM
Octania's Avatar
Mike
68-9 LH mirrors are hard enough to find... RH, nigh impossible. On rare occasion an NOS one appears on epay... cannot compete with the Rich Man, nor wait yrs for 1 to appear.
New in box
The label with confusing Stuart Pidasso Part Number
The 60 degrees base to stalk angle, with mirror head inclined upward somewhat on this RH 70-72 unit.
Cavity and 3-4 threads MIA
Other screw hole with weak threads also
Honestly, they can't put a coat of wax, a spray of oil or grease or SOMETHING on the threads when they manufacture these things? And a drilling clue...
Easy stalk angle ck with any 90 degree corner
Side by side taste test comparison
70-72 not on the door vs '68 correct RH Mirror on the door
Old Apr 7, 2013 | 03:13 PM
Octania's Avatar
Well, yes
SM6865R 1968-69 Right Mirror
$64.50
Should have gone there first I guess.
Now, can anyone attest that it's not the exact same thing?
Old Apr 7, 2013 | 03:48 PM
z11375ss's Avatar
Nope. All I know is mine was a complete PITA. The worst part was the fact I bumped into the original one with my body and it snapped at the door.
Old Apr 10, 2013 | 03:41 PM
Mike77's Avatar
that rare? Wow!
The point being if customer's send the POS back for a full refund, the seller would be stuck with unsellable inventory. Hopefully they would have their manufacture clean up their act. I am obviously being optomistic.
I too have purchased POS after market parts. I have sent many back for a refund. I would rather do without until I find a GOOD part to install. No more OPG or the like for me.
Mike
Old Apr 11, 2013 | 03:30 AM
Yellowstatue's Avatar
This will teach you to buy a bushel full of these hard to find parts thirty years ago and save yourself all of this harmful stress...
Old Apr 11, 2013 | 04:03 AM
allyolds68's Avatar
Originally Posted by Octania
Well, yes
$64.50
Don't be so quick to go to Fusick. I've got a set of mirrors for mine from there and they suck. The ball and socket is so loose that closing the door causes the mirror to move...a lot.
I've tried the epoxy trick and that didn't work on the chrome either. Next I'm going to just stake the GD thing
BTW you can actually get them for about $55 each on ebay from Fusick (plus shipping of course)
http://www.ebay.com/itm/1968-69-Cutl...ht_1113wt_1161
Old Apr 11, 2013 | 06:44 AM
Indy_68_S's Avatar
Good info...
I want to add a RH mirror on my '68. I let a few NO$ ones slide because my car will never be 'concour$' level and figured one of the repops would do...
Now I know... Thanks !
Old Apr 11, 2013 | 09:07 AM
Octania's Avatar
no reply from the seller
had to open an epay/paypal case and hope that gets their attention.
looking into NO$ unit instead.
buyer said no, but MY car could use an NOS one!
Update noon Thursday
postage for return of POS was sent
seller failed to send his ship-to address as I requested
another minor fail
says proper RH mirror "checked over really good" is on the way.
so far so good.
Th after work the correct RH mirror was here, sent other back Friday
So far so good, the current RH unit has much better threads and the bolts are not oxidized in place.
Octania
Jul 17, 2013 08:07 PM
ozzy-64
Body work
Jun 15, 2013 10:01 AM
Octania
Apr 23, 2013 06:11 PM
Octania
Apr 9, 2013 03:57 PM
slowolds
Jun 14, 2010 09:40 AM
