Convertible top pump install trick?
Old Jul 31, 2014 | 06:11 PM
Tom442's Avatar
Besides a little lube job, is there a trick to getting those three pointy grommets to go down into the bracket? And no hair wisecracks please
Old Jul 31, 2014 | 08:11 PM
Texas69's Avatar
First, put a little oil on the grommet. Then, if they are like my grommets, stick a small, blunt tipped object in the small hole on the top side of the grommet as you insert the grommet into the hole. This stretched the grommet and helped push it through.
I used a small drift punch. Do not use a nail or other sharp object since it will just puncture the grommet.
Old Aug 5, 2014 | 06:31 PM
Raysin's Avatar
Smile Installation of pump
I used silicone spray and a 3/16 ball nose Allen wrench and was done very quickly.
Old Aug 11, 2014 | 08:55 PM
Tom442's Avatar
You are correct sir!
Plenty of silicone spray and a little rotational action and they popped home.
Tom
JpMotorsports
Jun 26, 2015 03:37 PM
viper771
Nov 12, 2011 03:38 PM
gearheads78
Jul 22, 2011 08:54 AM
OLDSRALLYE350
Oct 31, 2010 12:32 PM
Barneyo
Feb 8, 2008 05:18 AM
