adjusting my 68 cutlass hood
Old Feb 13, 2011 | 09:25 AM
stingger68's Avatar
adjusting the hinges to the fender im guessing is were im needing it done. the hood is rased up in the back by the wind sheld (on both sides). do i slide the hinges down or up to fix this? i have them all the way down and it stays the same unless i push the hood down in the back. thanks
Old Feb 13, 2011 | 09:36 AM
First they may need a bit lubrication, then I would check the following. Are all your gaps set, so that the hood is foward and lined up in front with the fenders? Is there any thing in the way in the back like the rubber guides on the fenders, or the rain weather strip that runs across windsheild valance? If all those are ok, then I would look at the hinges for worn rivots or possibly the hinge springs.
Old Feb 13, 2011 | 09:43 AM
stingger68's Avatar
im going check for anything in the way.. it was shutting great before i took it and the fender off.
Old Feb 13, 2011 | 10:04 AM
stingger68's Avatar
well nothings in the way
Old Feb 13, 2011 | 10:09 AM
allyolds68's Avatar
Make sure you put the spacer back in at the rear connection point to the hood (Assembly Manual page 11-187)
Did you mark the hinge location before taking everything apart? It sounds like the rear of the hinge is too high
Old Feb 13, 2011 | 10:29 AM
stingger68's Avatar
i don't have a Assembly Manual for my car. i i marked the passangerside but not the driver side(i had to beat out were a shels fell on that side) ill recheck the high of the back of the hinge.
Old Feb 13, 2011 | 10:33 AM
There are 3 bolts on the side of the hinge that help align the height of the hood. I had a similar problem on my 72. What I did:
open the hood
loosen the 2 back bolts
have someone push up on the hood.
tighten the two bolts back down
carefully lower the hood and check for alignment. You might have to repeat this process a few times to get it just right. GM fit from the factory wasn't always perfect either. There could be a height difference of 1/8" that was within factory specs.
Shimming the fenders will also raise the hood by the same amount as the shim, so shimming isn't always the answer.
Play with it and see how it works out.
Old Feb 13, 2011 | 12:34 PM
stingger68's Avatar
got it lol the extra set of hands worked out great lol. it still have a lil bit of highness in the back but it'll work.
Old Feb 13, 2011 | 05:11 PM
Bluevista's Avatar
Registered
I love it when a plan comes together.
In the future remember that to adjust those type hoods you raise the front of the hinge to lower the hood and lower the hinge in the front to raise the hood.
People make the mistake of lowering the hinge in front to get it down in the back and when they close it and the hood is higher than before they go nutso.
It may sound bass-ackwards but that's the way it is.
Old Feb 13, 2011 | 05:49 PM
stingger68's Avatar
i know now lol
Old Feb 14, 2011 | 08:10 PM
markccar's Avatar
hood
put a 1/16 or 1/8 shim between the hood and hinge on the rear hood bolt and it will bring the hood down,
Old Feb 15, 2011 | 03:10 PM
stingger68's Avatar
kool i will try that
dynamic88builder
Dec 30, 2019 07:24 PM
russell-t
Brakes/Hydraulic Systems
Feb 19, 2015 09:21 AM
flatoz
Apr 16, 2009 05:06 AM
59-59-59
Jun 30, 2008 01:01 PM
ventport
Alero
Nov 5, 2006 04:17 PM
