Aluminum Connecting Rods....
Old Aug 17, 2012 | 08:02 PM
Stevec's Avatar
Is it worth using aluminum connecting rods on a street 455 engine that will produce 450-475hp? I know the lighter the rotating assembly the better.
Just currious....
Old Aug 17, 2012 | 08:16 PM
380 Racer's Avatar
I never put them in my race engine.
Old Aug 17, 2012 | 09:04 PM
70Post's Avatar
short answer "NO!!"
Old Aug 17, 2012 | 09:12 PM
ihengineer76's Avatar
I would never run them. On a street motor, you are not really going to notice the gain from it anyway. Spend your money on parts that will get you more HP per $. Aluminum rods on street engines are good for bragging and are lighter when you are picking up whats left of the motor off the pavement.
Old Aug 17, 2012 | 09:47 PM
ah64pilot's Avatar
We got into a debate about this a few months ago. The fact is that modern aluminum rods made by BME are strong enough to be used on the street. However, the cost of the rod doesn't make it feasible. You will spend so much money on the rods and unless you're spinning your street engine to 7500 RPM you won't ever realize the benefit.
Waste of money unless you're running 1,000 hp at 8,000 rpm
Old Aug 18, 2012 | 12:40 PM
Run to Rund's Avatar
Get aftermarket steel rods and spend the extra money on light pistons and pins. You can find pistons and pins that save about a half pound in each cylinder. That will ease the loads on the rod bearings and rods.
Old Aug 18, 2012 | 12:50 PM
Stevec's Avatar
Thanks for the info guys! I think I'm gonna just go with some Eagle rods.
What other brand of rods are there for the Olds? I know Olds Performance Products makes them, has anyone used them?
Old Aug 18, 2012 | 01:03 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Cat is the other brand, cheaper if you can find them. Supposedly high quality, despite being made in China.
Old Aug 18, 2012 | 01:07 PM
Stevec's Avatar
Eagle it is!
Thanks guys!
Old Aug 18, 2012 | 02:05 PM
copper128's Avatar
Lt. Buzzkill (ret.)
I don't think the CAT Olds rods are available anymore.
RPM International makes the Mondello I-beam rods.
They sell them under PN# LG3-6735I and you can buy them direct for under $400.
http://www.racingpartsmaximum.com/sae4340ibeam-2.html
Old Aug 18, 2012 | 03:40 PM
ah64pilot's Avatar
So go with the Eagle rods, lmao!
Old Aug 18, 2012 | 03:51 PM
Stevec's Avatar
Mondello? No thanks!
Old Aug 18, 2012 | 05:00 PM
380 Racer's Avatar
Olds Performance Products doesn't MAKE anything.
Old Aug 18, 2012 | 05:18 PM
Stevec's Avatar
380 who does make O.P.P stuff. They seem like a good place to do biz with.
Old Aug 18, 2012 | 06:10 PM
cutlassefi's Avatar
X2, Andy Miller is a jerk. Buy the Eagles wherever you can and just have them checked.
Old Aug 18, 2012 | 06:37 PM
380 Racer's Avatar
Where ever he can get them done as cheap as possible and quality is not considered. Mark is right.
Old Aug 18, 2012 | 08:51 PM
Octania's Avatar
Huh, after my experience with "C.A.T." SBO halo girdle...
I would not buy ANYTHING with that brand. With the intention of using it, anyhow.
http://www.ebay.com/itm/150646769737...84.m1555.l2649
Note that the "pare", er, the part was very poorly made. No provision for a dipstick tube to pass thru. 5140 steel, my ****. Studs snapped off before getting to 80 ft-lbs. Nuts dig into the girdle material. Girdle interfered with oil pan at the front. Studs have no recess hex to install/ remove, so double nutting is the clever plan there- then the nuts seize to the stud because they are made of SHYT.
AVOID LIKE THE PLAGUE.
Old Aug 18, 2012 | 09:00 PM
Your right, Cat usually is junk, those were the exception.
Old Aug 19, 2012 | 03:48 AM
Boldsmobile's Avatar
Bill used them in his EMC motor. I haven't read anywhere that there have been quality issues with these rods. Please elaborate.
CHARLOTTE
Jul 8, 2011 01:57 PM
long 64
Jun 1, 2011 06:39 PM
442 Guatemala
Mar 18, 2009 09:40 AM
dan2286
Dec 17, 2008 03:43 PM
