Buyer beware
Old Mar 31, 2026 | 05:54 AM
cutlassefi's Avatar
Buyer beware
Hi guys,
I’m currently rebuilding an H headed 455 442 W 30.
It came to me originally because of excessive oil consumption, about a qt. every 500 miles, even though it was recently rebuilt. After tearing it apart, I found numerous mistakes and careless assembly practices as well as now, questionable machining operations as well.
The last statement is the reason for this post. I typically run into mistakes and such other shops do on Oldsmobile engines in general. But what I found yesterday is unacceptable. This engine had very good oil pressure, but when I pulled it apart and saw the Crank, etc., in this condition, I was confused as to how it would have such good oil pressure with the crank and bearings in less than optimum condition.
In addition, all the main saddles were .0015-.002 OVER the high spec. So how did it still have real decent oil pressure?
I found they “adjusted” the bearing clearances by grinding the crank only .008 under, not the full .010. That tightened up the bearing clearance, even with the larger main saddles. This was a blatant machining practice to circumvent doing it the correct way(ie align honing correctly and adjusting clearances from there). Stuff like this is unacceptable to me, and should be to everyone as well. The cost of this rebuild when done in 2021 was over 7k, and it was basically just a hone, re-ring, with a new flat tappet cam.
I’ll finish by saying the shop that did this is in Greeley CO.
Old Mar 31, 2026 | 10:37 AM
Geez.. what a mess!
Old Mar 31, 2026 | 04:24 PM
hotrod442's Avatar
Is it the place that does the YouTube videos by chance?
Old Apr 1, 2026 | 04:01 AM
BillK's Avatar
Looks like a ton of crap went through it too. Did you find what was causing the oil consumption ?
Old Apr 1, 2026 | 04:34 AM
cutlassefi's Avatar
Yes, loose guides, worn valves, questionable seals.
Rings looked OK, but the cyls were a bit barrel shaped as well.
Old Apr 1, 2026 | 04:37 AM
cutlassefi's Avatar
Dunno, what place is that?
Old Apr 1, 2026 | 06:32 AM
oddball's Avatar
Yikes. I'd understand a bare-budget "git 'er done" rebuild going that direction but a $7k rebuild bill? Wow.
Old Apr 1, 2026 | 06:59 AM
hotrod442's Avatar
Jim's Automotive
Old Apr 1, 2026 | 08:11 AM
cutlassefi's Avatar
Jim's Automotive
No, not it. But if someone guesses it, I will say it, or if someone wants to PM me, I will tell them as well.
Old Apr 1, 2026 | 10:49 AM
CANADIANOLDS's Avatar
not uncommon to see GM factory bearings +plus on the bearing OD to compensate for out of spec main saddles back in the 60’s and 70’s. I’ve seen it many times.
but today that’s a no go when doing a build not coming down an assembly line.
Old Apr 1, 2026 | 10:52 AM
how’s the valve sticking open issue coming along with that 400G block?
that’s twice now…hopefully someone doesn’t tag you online for that problem like you are trying to do with this bearing problem..because, that would suck.
Old Apr 1, 2026 | 06:55 PM
cutlassefi's Avatar
All fixed, defective guide, kept swelling.
And that’s why I run them extensively, not just a pull or two.
They don’t leave until they’re right, unlike the one in this post.
oldaman
Dec 27, 2018 07:37 AM
steve walker
Jul 31, 2014 03:41 AM
OLDSmobility
Mar 19, 2011 05:15 AM
Topless72
Apr 9, 2008 11:47 AM
bbolds442
Mar 31, 2008 07:26 PM
