Rocker bridge..
Old Dec 30, 2024 | 10:07 AM
Tancuda's Avatar
Rocker bridge..
Hi, just saw a snapped rocker bridge,
Do you think I could give a try with this one on ebay ?
Or should I use an aftermarket ?
The rockers are in good shape....
Old Dec 30, 2024 | 04:41 PM
442Harv's Avatar
I would replace them all with aftermarket steel ones.
Old Dec 30, 2024 | 07:16 PM
Tancuda's Avatar
Thanks for the advice, any aftermarket ?
Saw those Melling at rock auto...
Old Dec 30, 2024 | 07:27 PM
Sugar Bear's Avatar
IMO the one on eBay would be fine. If you replace them all with steel will you start the MAW process and buy all new rockers? Ya' know while the rockers are off, the valve seals...
Old Dec 30, 2024 | 08:07 PM
Tancuda's Avatar
HAAAAA ! I know your right, probably try one original, hope it will not snap when thightening !
Old Dec 30, 2024 | 08:18 PM
Sugar Bear's Avatar
Have both cam lobes on the base circle, no lift or tension on the rockers while torquing and you'll be good. Oil it well
Old Dec 31, 2024 | 05:32 AM
Tancuda's Avatar
Thumbs up
Thank you, will do that
Old Dec 31, 2024 | 06:28 AM
Run to Rund's Avatar
I put moly cam lube on the pivots, pushrod *****, etc. for break-in. I have never broken a bridge even when a valve was open, by tightening the open side first, and following with the other bolt as appropriate, being careful, not acting like a gorilla. I am still using the same rockers I got in the junkyard in the 1970s.
maitrepathelin
Dec 27, 2024 08:37 AM
friesjh
Sep 16, 2021 06:10 PM
JIM'S w30
May 19, 2021 04:56 PM
billmerbach
Mar 8, 2015 06:56 PM
