IMO the one on eBay would be fine. If you replace them all with steel will you start the MAW process and buy all new rockers? Ya' know while the rockers are off, the valve seals...
HAAAAA ! I know your right, probably try one original, hope it will not snap when thightening !
I put moly cam lube on the pivots, pushrod *****, etc. for break-in. I have never broken a bridge even when a valve was open, by tightening the open side first, and following with the other bolt as appropriate, being careful, not acting like a gorilla. I am still using the same rockers I got in the junkyard in the 1970s.
