Diesel oils
Old Jun 4, 2024 | 07:08 PM
bw1339's Avatar
Diesel oils
What's the consensus in using modern diesel oil for our engines? Many of them still use flat tappet cams and don't seem to have cam wear issues.
Old Jun 5, 2024 | 07:53 AM
Even diesel oil is seeing a reduction in zinc. Just get high zinc automotive oil and be done with it.
Old Jun 5, 2024 | 08:42 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Me and a lot of other folks on here use Valvoline VR-1 Racing Oil which has adequate zinc in it.
Old Jun 5, 2024 | 08:50 AM
Old Jun 5, 2024 | 08:56 AM
illumined's Avatar
1978 Ninety Eight
I asked a Chevron about historical zinc levels in the late 70's and was told it had between 1000 and 1200 PPM, while today it has around 700-800. The closest I've found has been Valvoline VR1, which you can buy directly from them very cost effectively, and that has a content of 1300ppm. One thing you don't want to do is have something with too much zinc, it's not good for it either.
Last edited by illumined; Jun 5, 2024 at 09:01 AM. Reason: Misremembered Zinc levels
Old Jun 5, 2024 | 08:57 AM
I've been using Lucas Hot Rod conventional for years now. My cam still seems to have lobes.
Old Jun 5, 2024 | 08:58 AM
bw1339's Avatar
Thanks guys.
One thing I don't understand. I have put hundreds of thousands of miles on Jeep (AMC) 4.0 engines since the zinc levels were lowered years ago. I used Mobil 1 at 10,000 mile change intervals and I never had motor trouble of any kind. There are millions of these still around and cam/lifter failures in these engines are very rare. As these vehicles are old now, I am willing to guess that the kind of service they get is not to the same level as an obsessive classic car owner gives to his beloved car.
The diesel oil I was going to try was Shell Rotella T6. I use synthetic in my diesels and never had a problem. Thought it was worth a shot in my 455 with new seals/gaskets.
Old Jun 5, 2024 | 09:00 AM
Here's an even more interesting list.
https://www.speed-talk.com/forum/viewtopic.php?t=33547
Old Jun 5, 2024 | 09:54 AM
I use Rotella T4 15W-40 in my 71 Oldsmobile. It works great. Apparently, it has plenty of zinc too.
http://pqiadata.org/Shell_Rotella_T4_15W40_4192017.html
Old Jun 5, 2024 | 10:08 AM
ourkid2000's Avatar
My grandfather left me a lifetime supply of Quaker State Deluxe oil in cans from the 70's (Pennsylvania Grade only). There's nothing like vintage oil from a can. I checked, the gas milage is better too.......she gets 40 rods to the hogshead. Not too shabby.
Old Jun 5, 2024 | 10:22 AM
bw1339's Avatar
You may find this interesting.
Old Jun 5, 2024 | 10:23 AM
Seriously though, there's a whole other thread somewhere in here about why you shouldn't use old motor oil. Can't remember what the age cutoff was, but I'm thinking anything in a can that requires a filler spout qualifies as old.
Old Jun 5, 2024 | 10:52 AM
cutlassefi's Avatar
Unfortunately, this does not tell the whole story Joe. The amount of detergent in the oil will also affect the benefits of the zinc.
Old Jun 5, 2024 | 10:55 AM
66_Jetstar's Avatar
I believe the zinc content is only an issue for an engine with heavy spring rates and fast ramp/high lift cams. A 4.0 jeep motor probably has a very low lift/duration cam for low end power.
Old Jun 5, 2024 | 01:23 PM
A few years back I emailed Shell about using Rotella in older cars that required high zinc content. They said don't use it.
Old Jun 5, 2024 | 01:35 PM
It was his thread.
Old Jun 5, 2024 | 02:12 PM
It was his thread.
Well, apparently we didn't scare him straight.
Old Jun 6, 2024 | 02:24 AM
OLDSter Ralph's Avatar
Joe P, did you check the date on the posting ? by 540 RAT » Mon Nov 26, 2012 3:14 pm
That data was collected over several years by 540 Rat, I think as far back as 2005. Even if al the oils were all tested in 2012, that data would still be 11 years old and subject to changes.
Old Jun 6, 2024 | 05:21 AM
Fair point, but ZDDP levels have only come down.
Old Jun 6, 2024 | 06:19 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Lake Speed Jr, an oil analysis specialist talked about the new VR1 formula. They have a great balance according to him. As mentioned detergent levels play a big part and diesel oil has very high levels which negates the ZDDP. Some of our diesel oils have 800ish ppm in the full synthetic variety that our company manufacturers.
Old Jun 6, 2024 | 07:30 AM
bw1339's Avatar
From Shell's website:
Zinc is an important component in Zinc dialkyldithiophosphate (ZDDP) which forms a sacrificial anti-wear film in an engine to help protect internal components such as a camshaft. Most Shell Rotella engine oils, including T6 5W-40 Full Synthetic Heavy Duty Diesel Engine Oil, contain approximately 1200 ppm of zinc which will benefit older and high-performance engines.
Old Jun 6, 2024 | 07:40 AM
ourkid2000's Avatar
https://youtu.be/W48nygk1mlc?si=0sxE5gDd8EgL5rwx
So that stuff is only available in 20W-50? Isn't that a little heavy for cars that typically want 10-30 or 10-40?
Old Jun 6, 2024 | 08:08 AM
No, it is available in 10W30 and 20W50, conventional and synthetic. Also available in single weights 30 through 60 in conventional.
Old Jun 6, 2024 | 08:11 AM
ourkid2000's Avatar
Do me a favor......go to Valvoline's website and show me where you see the other options available. Can just post the link for it here if you find it.
Old Jun 6, 2024 | 08:43 AM
VR1 Racing Motor Oil – Valvoline (valvolineglobal.com)
Old Jun 6, 2024 | 08:53 AM
ourkid2000's Avatar
Ahh, I get it......not available in Canada. It was directing me to the Canada site where it isn't an option. Strange that you can't get anything other than 20-50 here.
Old Jun 8, 2024 | 05:45 AM
DR_DAN's Avatar
Diesel oil have way too much detergent in them. I can’t understand why people just don’t buy good oil suited for intended use
Old Jun 8, 2024 | 06:15 AM
I would think that the alternative internet suppliers, Amazon, Rockauto, Summit, Jeggs, ets, would all ship to Canada.
Old Jun 8, 2024 | 07:04 AM
I bought 2 gallons of 15w-40 diesel oil at Wally World yesterday and it says right on the container that it's appropriate for gasoline engines.
https://www.walmart.com/ip/Super-Tec...llons/16213443
Old Jun 8, 2024 | 07:37 AM
cutlassefi's Avatar
Uhhh, I just went to that link and put in, more specifically, 1970 Olds Cutlass, 455 for the vehicle. Guess what, it says DOESN’T fit that vehicle. You took it at face value.
But use it if you like, it’s your money.
Old Jun 9, 2024 | 05:53 AM
  #31
bw1339's Avatar
Adding to the old oil discussion.
Chuxter
Dec 14, 2023 07:29 AM
Onit
Jul 2, 2022 10:17 PM
dfoisy
Apr 9, 2017 03:26 AM
Smitty275
Jul 20, 2014 03:23 PM
RROLDSX
Mar 8, 2013 05:50 PM
