Mobil 1 15w50 Zinc content
Old Apr 1, 2017 | 12:47 PM
dfoisy's Avatar
This may not belong here but I stumbled across this oils specs after I wiped the cam in a 396 I used to have. Just checked and this was last updated March 2017 so it still applies. Phosphorous is 1200 ppm and ZINC is 1300 ppm. Cheap off the shelf insurance available at Walmart for those of us still running flat tappet cams!
Old Apr 1, 2017 | 01:47 PM
Thanks. Is there zinc in the other weights or is it only in the 15W-50?
Old Apr 1, 2017 | 02:04 PM
RROLDSX's Avatar
I use it in my Harley. Much cheaper than any other 20W50 motorcycle oil you can find.
Old Apr 1, 2017 | 02:33 PM
dfoisy's Avatar
Everything but Euro spec 0w40, diesel, v twin and racing is all 900 or less. The racing has 1850 ppm zinc!
Old Apr 4, 2017 | 06:04 AM
brownbomber77's Avatar
Damn, only $25 for 5qt...I only use Mobile 1 in my Cruze and 5.3 Avalanche.
Old Apr 4, 2017 | 06:08 AM
Also, Valvoline VR oil supposedly has north of 1000PPM ZDDP
Old Apr 4, 2017 | 03:11 PM
cutlassefi's Avatar
Don't get totally hung up on the amount of Zinc in the oil. Too much can inhibit ring seal.
I've been using the ZR-1 now for a couple of years. 0 issues. I think it has just the right amount for most applications.
Old Apr 4, 2017 | 03:21 PM
Zr-1?
Old Apr 4, 2017 | 03:56 PM
Zr-1?
Yeah, what's that?
Old Apr 4, 2017 | 05:15 PM
cutlassefi's Avatar
Valvoline VR-1, my bad.
Old Apr 4, 2017 | 06:37 PM
Mark what viscosity do you use and what oil pressure do you look for hot?
Old Apr 4, 2017 | 07:07 PM
cutlassefi's Avatar
20W-50 because I use looser than stock clearances. Once up to temp (about 180-195*) I normally have a 60 psi or so during a dyno pull.
Old Apr 4, 2017 | 08:07 PM
What pressure at idle?
Old Apr 5, 2017 | 07:45 AM
cutlassefi's Avatar
25-30@850-900rpm.
Old Apr 5, 2017 | 08:09 AM
I only ask as this question comes up from time to time.
Old Apr 5, 2017 | 09:58 AM
dfoisy's Avatar
Excellent! That's my pressure at idle and running at operating temp so that is good to know!
Old Apr 5, 2017 | 04:59 PM
Kennybill's Avatar
Stock oil pump?
Old Apr 6, 2017 | 06:09 AM
dfoisy's Avatar
I assume it's high volume as I didn't build the engine because it jumps straight to 60 psi with any throttle increase
Old Apr 9, 2017 | 03:26 AM
AK71CutlassS's Avatar
Just got some VR-1 10W-30. Gunna run it in my 455. Seems to be good reviews on VR1
olds 307 and 403
Jun 18, 2016 09:03 PM
auto_editor
Feb 18, 2011 09:34 AM
don71
Dec 24, 2010 04:24 AM
Rallye3501970
Mar 28, 2009 02:05 PM
gearheads78
Jan 27, 2009 01:09 PM
