1961 Olds 98 Oil Drain Plug Size
Old Feb 21, 2024 | 03:51 PM
eggydrummer's Avatar
Seeing if anyone knows where I can get a new oil drain plug for my '61 Olds 98. 394 engine. It has the recessed star pattern. You use a 1/2" ratchet with no socket to remove it from the pan. It is a 22mm diameter, with what looks like fine threads. The picture below is NOT the drain plug currently in the pan. This is one I picked up that I was told was correct, but the threads are incorrect.
This is the INCORRECT plug. I am after the same diameter, but the threads must be fine.
Old Feb 22, 2024 | 06:07 AM
Do you have an old drain plug? If so, I'd take it into the auto parts store or hardware store to match to a new one. If you don't have the OE drain plug take that plug into the store and get a few different drain plugs that are close to that one. Make sure you keep your receipt so you can return the ones you don't need.
Old Feb 22, 2024 | 08:47 AM
Charlie Jones's Avatar
Phantom Phixer
This drain plug is a really odd bird.
It was used on only Olds V8's from 61 thru 65 except 215's.
It carried factory part number 577646.
You are very unlikely to find one in a hardware or auto parts store.
Your best hope is to find a good used one from someone who has parted an engine out.
Try deadds on this forum, he has parted several 394's.
Old Feb 22, 2024 | 10:23 AM
Sugar Bear's Avatar
Charlie, Is it the same as used in 64-65 330, 400 & 425's or is it 394 specific? If it is the same someone on the forum will have one.
Old Feb 22, 2024 | 04:48 PM
v8al's Avatar
Registered Olds Owner
Recently discussed in the forum, though never determined what the actual pitch of the thread was.
1961 Starfire Engine Oil Pan Drain Plug
Old Feb 22, 2024 | 06:29 PM
Phantom Phixer
Charlie, Is it the same as used in 64-64 330, 400 & 425's or is it 394 specific? If it is the same someone on the forum will have one.
Yes, it is.
Parts book says 61 thru 63 except F-85 .
And then all 64 and 65 V8's
2blu442
Aug 11, 2023 06:52 AM
outrightolds
Jun 14, 2022 02:38 AM
zekecut70
Oct 25, 2021 05:42 AM
onetogofast
Oct 12, 2014 07:27 PM
tpawlik
May 8, 2011 08:19 PM
