PCV valve grommet installation
What's the trick to installing a new PCV valve grommet into the D-hole in the RH valve cover? I've tried Dawn dish soap as a lube and have lost feeling in both thumbs trying to install with no success yet. New air tube grommet into the LH valve cover was no problem...
Thanks.
Thanks.
I recently found out getting a 57 year old original one out is harder than installing a new one.
Heat and silicone grease with assist from a pry stick like this.
Also, use sealer or it will weep oil.
Almond900
Feb 26, 2016 02:56 AM
