1966 425 rebuild kit
Old Jul 31, 2022 | 07:12 PM
Tgbunch's Avatar
Has anyone used Clegg Engines for a master rebuild kit?
Old Aug 2, 2022 | 07:06 AM
sysmg's Avatar
I would beware of any full kit for a 425. Most vendors don't realize that it's different than a 455 and could send you improper parts. Cam is different, lifters can be different. Piston, rods and cranks are different. Not sure about bearings. Better to contact an Olds expert like Mark Remmel or Andy Mark to get the proper parts. Otherwise you could be in the middle of a rebuild and have your machinist call you and say these parts don't fit.
Old Aug 2, 2022 | 07:18 AM
edzolz's Avatar
Also you might contact costpenn on this site. He owns a company (Enginetech) that sells rebuild kits. Or search for their website.
Old Aug 2, 2022 | 07:19 AM
cutlassefi's Avatar
Mahle makes an off the shelf piston kit for 425’s, Molnar makes rods. Everything else can be gotten fairly easily.
Old Aug 2, 2022 | 08:43 AM
Tgbunch's Avatar
Thanks guys for your help. My local auto wasn’t very helpful.
Old Aug 3, 2022 | 04:41 AM
BillK's Avatar
I assume you are looking to a stock rebuild. I did a 425 about a year ago and had no problems sourcing parts through my normal supplier. Ask your machine shop if they can get you what you need. That way you will be fairly sure to get the correct parts.
Where are you located ?
Old Aug 3, 2022 | 07:51 AM
Tgbunch's Avatar
I live in Oklahoma. My machine shop was able to locate me a set of 40 oversized Pistons.
Old Aug 3, 2022 | 08:12 AM
BillK's Avatar
They should be able to get you an entire engine kit.
Old Aug 3, 2022 | 08:17 AM
Tgbunch's Avatar
He is getting everything thing I need to rebuild my engine. Thanks
Leander
May 22, 2017 12:13 PM
67BB
Apr 16, 2013 01:48 PM
808olds
Oct 7, 2010 10:05 AM
delta
Jun 30, 2008 01:41 PM
delta88NC
Mar 24, 2007 07:50 AM
