who makes a good rebuild kit?
I guess I'm not sure exactly what you are looking for, then. A re-ring kit plus cast pistons (if needed) gives you the "basically stock" rebuild that you asked about. If you reuse your current pistons, then all you need is the re-ring kit.
Unless you have a complete automotive machine shop at your disposal, you will likely drop the heads off to be rebuilt. That shop will install new valve seals and any other new parts the heads need. The Summit re-ring kit includes everything above (including the valve seals, actually) except the freeze plugs, oil pump, cam bearings, and timing set. Unless you have a cam bearing installation tool, you're going to have the machine shop install the cam bearings after hot tanking the block, so you don't need those anyway. Brass freeze plug sets for an Olds motor run around $18. The timing set is your call whether you need one or not and whether you want stock or roller. There are many to choose from. Same with the oil pump - keep the original or get stock or HV. No Olds gasket set ever comes with the intake gasket, so you'll be buying that separately anyway.
We've already spent more time talking about this than it would have taken RockAuto to ship these parts to your door.
67bb . No re build kit will truly ever be complete. No re ring kit will include an oil pump , cam bearings. Timing chain. You do have to do some piecing together. If you are doing a rebuild with new pistons and speed pro does not offer their rebuild kit anymore. You will need new pistons , a re ring kit, cam bearings, oil pump, timing chain, a cam, oil pump pick up , also depending on your pistons if new using a re ring kit sometimes is not good as for the most part they come with cast rings. So usually a rebuild taylored to a build requires buying parts individually.
http://www.northernautoparts.com/Pro...?ProductId=700
Includes oil pump, cam, lifters, timing set.
Oversizes can be had, and certain modifications can be done to kit, ie., changing part manufactures, different cam, roller chain, etc.
Everyone that has offered an answer thank you, I appreciate it. Granted I haven't rebuilt any engines in over 20 years I have done 30 or 35 in my time. I used to get things BI (before the interenet) from PAW mostly and they did have complete kits. You get the machine work done, the crank turned and put everything else in NEW. I call that complete even though they didn't include a crank. So I guess we're all wrong. I've restored several dozen corvettes in my younger days but never messed with Oldsmobiles until my wife went out and bought 3 in the last 2 months. I was just trying to learn. It would have been easy enough to say nobody offers one. See? Easy. I imagine I can piece it together at autozone but I like buying kits becasue it's quite a bit cheaper.
Had someone mentioned Rock Auto to begin with I would have checked there immediately. I'll take a look at nothern auto as well. Thanks again.
Unfortunately, that option is long gone. I drove past the PAW building in Chatsworth a few years ago and it looked empty. If you go to their website (http://www.pawinc.com/), you get this:
EFFECTIVE 9/30/2010
P.A.W.IS ONLY SELLING THROUGH ITS EBAY STORES AT
"HOT ROD ENGINEPARTS "
"EARLY HEMI ENGINEPARTS"
