1966 425 rebuild kit
I would beware of any full kit for a 425. Most vendors don't realize that it's different than a 455 and could send you improper parts. Cam is different, lifters can be different. Piston, rods and cranks are different. Not sure about bearings. Better to contact an Olds expert like Mark Remmel or Andy Mark to get the proper parts. Otherwise you could be in the middle of a rebuild and have your machinist call you and say these parts don't fit.
I assume you are looking to a stock rebuild. I did a 425 about a year ago and had no problems sourcing parts through my normal supplier. Ask your machine shop if they can get you what you need. That way you will be fairly sure to get the correct parts.
Where are you located ?
