Power Steering bracket for Edelbrock heads and tall valve covers
Old June 28th, 2018, 06:29 PM
Do Damage
67CSConvert455's Avatar
Mocking up brackets today on a 455 rebuild. I could probably get away with the stock alternator brackets but the stock power steering are a ‘no-go’. Anyone have a part number of the low mount brackets and pump I’m going to have to change to? Thanks in advance. Original power steering pump and brackets from a 1967 CS.
Does not fit with tall valve covers.
Tight but should work.
67CSConvert455 is offline
Old June 29th, 2018, 04:52 AM
All 1968-1990 PS pump brackets are dimensionally equivalent and put the pump in the same low-mount location, so any of them will work. Naturally, don't forget the two spacers.
joe_padavano is offline
Old June 29th, 2018, 09:52 PM
Do Damage
Joe, Thanks for the response. I found this currently on e-Bay The setup is off of a 1970 Oldsmobile 98 with a 455.
Old June 30th, 2018, 02:52 AM
That will work. You will need the two stud-bolts for the front cover and the two spacers that go between the bracket and the block. Inline, OPGI, and others sell a kit with all that mounting hardware if you prefer.
Old June 30th, 2018, 06:19 AM
nicks1966's Avatar
When I did my 66 I had to cut off part of lower bracket to clear the steering box. Frame was checked and it was fine I was told Gm widened the frame rails for clearance starting in 68.
nicks1966 is offline
Old June 30th, 2018, 06:24 AM
That is correct. The 64-67 frames are about 1.5" narrower at the crossmember than the 68-72 frames. That's why the early cars used the high-mount PS pump and also why it's tough to find correct headers for the early cars.
Old June 30th, 2018, 11:48 AM
Do Damage
This going to be really helpful.
Most cost effective price I can find.
Thanks Nick and Joe. Inline Tube has it at the most cost effective price and a schematic too.
Old July 3rd, 2018, 08:15 PM
I have a friend with a 66 Cutlass, 455 and used the later low mounted power steering pump. It’s a tight fit but will go in there.
matt69olds is offline
brandon reynolds
January 12th, 2019 05:48 AM
Battenrunner
July 12th, 2018 05:45 AM
Dfulton
July 1st, 2018 11:37 AM
allyolds68
December 24th, 2015 06:08 AM
Freddy B
December 31st, 2012 11:27 AM
Quick Reply: Power Steering bracket for Edelbrock heads and tall valve covers
