Where to buy a 455
Old May 17th, 2018, 01:59 PM
rocket4421's Avatar
Where to buy a 455
Guys where can I buy a really good running 455. I have a 69 old 442 with a 400 motor in it I’d like to take that out and keep it fresh as long as possible but I would like to buy a motor that would run really good Without breaking my bank account anybody have any ideas thanks for the help
rocket4421 is offline
Old May 17th, 2018, 03:15 PM
scrappie's Avatar
I have a couple 455 core motors, 1 long block 70 motor (E) heads, spun bearing and short block (FA block) is taken apart for inspection. Both would need rebuilding but a stock rebuild may not be too pricey? These would need intake/carb, valve covers, brackets other accessories. PM me if interested.
scrappie is offline
Old May 18th, 2018, 07:20 AM
Kennybill's Avatar
If you don't want to "break the bank" you should put your location because shipping may break the bank. Jmo.
Kennybill is offline
Old May 18th, 2018, 07:57 AM
rocket4421's Avatar
Ohio. Thanks
Old May 18th, 2018, 08:45 AM
delete
droptopron's Avatar
What do you consider breaking the bank? Olds aren't cheap engines to build & its not like a SBC where you can order a crate engine
droptopron is offline
Old May 18th, 2018, 09:26 AM
rocket4421's Avatar
I was thinking somewhere around 5000.00
Old May 18th, 2018, 09:48 AM
Kennybill's Avatar
Well, that narrows it down to possibly 260 miles away if you were in Cincinnati for instance.
Old May 18th, 2018, 10:23 AM
rocket4421's Avatar
Columbus Ohio
71OldsCool
October 29th, 2016 08:35 AM
fuelbp
March 2nd, 2016 07:54 AM
chip-powell
February 1st, 2016 03:39 PM
Curts1970cutlass
October 27th, 2015 04:36 PM
lsutigers93
June 22nd, 2014 07:09 AM
Quick Reply: Where to buy a 455
