Yikes!
Old Apr 18, 2024 | 01:34 PM
72455's Avatar
1972 U code Supreme
Yikes!
How does this happen?? (Luckily I had a spare in the garage).
Old Apr 18, 2024 | 01:39 PM
Oooops. Misalignment, too loose or incorrect belt for application.
Old Apr 18, 2024 | 01:40 PM
v8al's Avatar
Registered Olds Owner
One problem is that your belts are on wrong. The alternator belt goes on first (closest to the water pump) and then the power steering belt goes on.
You could also have the wrong water pump pulley.
Old Apr 18, 2024 | 01:51 PM
72455's Avatar
1972 U code Supreme
Can anyone confirm this please? It would explain a lot.
Old Apr 18, 2024 | 02:01 PM
69455's Avatar
If not any of above brkt could be flexing
Old Apr 18, 2024 | 02:04 PM
I would think you could rapidly confirm via the CSM.
72455's Avatar
1972 U code Supreme
This has never happened before, so I don't think it's the water pump pulley.
Old Apr 18, 2024 | 02:05 PM
72455's Avatar
1972 U code Supreme
Misalignment caused by the belts being on wrong?
Old Apr 18, 2024 | 02:11 PM
Who knows. Incorrect spacers on brackets, incorrect brackets, spacers installed incorrectly on brackets, brackets installed incorrectly yielding to belt misalignment. It's rather well described in the CSM and the PIM.
Old Apr 18, 2024 | 02:19 PM
Old Apr 18, 2024 | 02:49 PM
72455's Avatar
1972 U code Supreme
Well, looks like I've got something else to work on...lol.
Now, if I could get some guidance on this, I'd be even further ahead.
https://classicoldsmobile.com/forums...squeal-178810/
Old Apr 18, 2024 | 03:46 PM
v8al's Avatar
Old Apr 18, 2024 | 03:57 PM
Belt misalignment as said above. I had that happen back in the 80s after an alternator replacement. Discovered there was a washer UNDER the pulley instead of ON TOP of the pulley. That was enough misalignment to cause the belt to roll at high RPM. Apparently it doesn’t take much misalignment to cause an issue.
Old Apr 19, 2024 | 03:39 AM
72455's Avatar
1972 U code Supreme
Refresh my memory...two nuts to loosen for removal of the p/s belt. One up top and one down below, correct?
Old Apr 19, 2024 | 04:12 AM
Muggard's Avatar
Two bolts on the front side (one up top and one near the bottom). There is also a nut on the rear bottom side. Loosen all 3.
Old Apr 19, 2024 | 04:06 PM
72455's Avatar
1972 U code Supreme
What's the trick to getting to the bottom bolt? It's pretty tight quarters down there, and I know I've done it before, but memory fails me...lol
Old Apr 19, 2024 | 04:54 PM
Muggard's Avatar
I use an open ended wrench. Tough to get a good bite on the bolt, so hopefully, you can break it loose farily easily.
Old Apr 19, 2024 | 05:05 PM
72455's Avatar
1972 U code Supreme
I tried that but there's no way to get a swing once I grab the bolt.
Old Apr 19, 2024 | 06:16 PM
72455's Avatar
1972 U code Supreme
Can someone please provide a pic? I'm in a time crunch.
Old Apr 20, 2024 | 02:46 AM
72455's Avatar
1972 U code Supreme
This is really frustrating me because I know I've done it before but I can't remember how. I've got to be overthinking it or I'm missing something. I know it wasn't this difficult for me the last time.
Old Apr 20, 2024 | 09:35 AM
Tedd Thompson's Avatar
Try a ratchet end wrench, you maybe get a click or to with that...Tedd
Old Apr 20, 2024 | 09:39 AM
72455's Avatar
1972 U code Supreme
Yup...that's my plan. I just wish I could remember how I did it last time. Do you think an offset box wrench would work?
Old Apr 20, 2024 | 10:30 AM
Can't recall exactly how I removed/re-installed that bolt but I'm nearly positive it was a swivel socket on a ratchet or a swivel adapter attached to a socket. Maybe an offset - don't recall. I have a set of 1/4" sockets & 1/4" ratchet wrench which has bailed me out in many instances. 1/4" sockets, swivels & ratchets are awesomely handy in tight spaces.
Old Apr 20, 2024 | 10:39 AM
72455's Avatar
1972 U code Supreme
Norm, do you think 1/4" drive would give me enough leverage?
Old Apr 20, 2024 | 11:02 AM
Dave - Removing that bolt isn't something I've ever routinely had to do. Wish I could answer that for you. Sometimes it's a combination of things including a small extensions & small hollow pieces of metal (pipe) over the wrench/ratchet. Think outside the box. Sorry, buddy. You'd be surprised the amount of force/leverage 1/4" ratchets, sockets provide.
Old Apr 20, 2024 | 06:17 PM
72455's Avatar
1972 U code Supreme
Now I remember what I did...I used the right size wrench...lol. Went back at it tonight after work and realized I was trying to turn a 1/2" bolt with a 9/16" wrench...Doh! Things went great once I figured that out...lol.
Old Apr 21, 2024 | 11:41 AM
herkguy's Avatar
Hehe….
Old Apr 21, 2024 | 12:01 PM
Old Apr 21, 2024 | 01:29 PM
72455's Avatar
1972 U code Supreme
Yep Norm...a lesson well learned...lol. I bet I wont forget again.
Old Apr 21, 2024 | 01:36 PM
Dave - Your most admirable quality is your honesty. Not many would even admit to having made this error. I hope you get the belt issue resolved.
Old Apr 21, 2024 | 01:39 PM
  #31
72455's Avatar
1972 U code Supreme
I already did Norm...switched them around last night. And I don't mind admitting my blunders...so much the better if others can benefit.
Old Apr 21, 2024 | 01:44 PM
  #32
Yeah, I recall me installing the oil pan gasket on my 350 twice and admitting how far too much gasket sealer I had used. That was painful especially while working under the car on jack stands w/ engine hoisted just enough (4") to get the oil pan free.
tkcutlass
Sep 20, 2023 08:09 PM
Rallye469
Aug 21, 2023 05:12 AM
tkcutlass
Oct 18, 2022 09:38 PM
Supernice88
Sep 21, 2022 04:52 AM
tkcutlass
Apr 3, 2022 07:52 AM
